So I'm still new to PLex, and this is probably a basic issue, but I didn't have any idea how to search for this one!
I've noticed that when you have two files that are related on your server, Plex will 'stack' them so that one 'poster' shows up for them in the client, and the poster will indicate a '2'.
In my case, I have I think the three different typs of problems with this that are possible:
First, I have 'the bridge on the river kwai', which is two separate files, and it recognized them, set one 'poster' for it, and stuck a 2 on it indicating it had both files, but when I hit play, it plays part two.
Second, I have both versions of "I am legend", (theatrical and extended) and it combined them, so i have only the one icon or poster, and it has the 2 on it. i have no idea whcih one is primary since they start the same.
The third is 'Malcolm X', which is two files, but isn't recognized as the same film, and just has two posters one 'Malcolm X' and the other 'malcolmx2'.
So my questions are: Does the 2 actually indicate, as I had presumed, that there are two parts to the film, and it will play both as you watch it (if not, what does it mean)?
If so, how do i tell it to play bridge on the river kwai 1 before 2? Is there a naming convention required, like there is for TV shows to work?
I expect the best idea for the two versions of I am legend is to just select the 'split apart' option, but how do I get it to recognize the other video as the extended cut?
For Malcolm X, I expect the answer for question 1 will give me an idea, but what's the best way to get plex to recognize that these are part 1 and 2 of the same film?
Thanks much for any input!!
Mick
