Plex thinks I am connecting External but I am on my local network
Hey Plex Community! So I have a network setup at my house where I have different IP blocks for different segments of my network. For example say the Plex server is running on 192.168.1.* range while I have a few other other ranges on the network 192.168.2.* 192.168.3.* with different devices that may utilize Plex. I want to be able to access Plex on the local network even if there is no internet access. I added the ip ranges for 192.168.2.0/24 and 192.168.3.0/24 in the LAN Networks section in my Plex server settings but when I connect from devices on those IP spaces, Plex still interprets them as remote connections and they only work over internet connection. Does anyone have any advice that can help?
Make sure there is no space after the comma.
192.168.2.0/24,192.168.3.0/24, not 192.168.2.0/24, 192.168.3.0/24.
192.168.0.0/16 should also work.
See [HowTo] Use Plex with No Internet
You may need to add entries for List of IP addresses and networks that are allowed without auth. Be aware that while it bypasses the need to login, it also gives any such devices full admin access to the server. It also means any age, content, etc restrictions are not enforced.
