Plex working with no internet
Server Version#:4.34
Just moved and have no internet for 2 weeks. LOCAL NETWORK is up, but I cant access plex from any Smat device on the lan.
Also, I tried specifying the local lan on the network tab, 192.168.0.1/24. IS that right, I dont see any examples in my searches. Or do they want it entered this way: 192.168.0.1/255.2555.255.0?
When I check the remote tab this what ip is assigned on the inside interface it does not show one.
Sorry for the typos. Using my cell phone
Here’s some good read on using Plex without internet and the related caveats
Thanks. Still working through this… should I see a local ip in plex? I can access via a browser.
Mod-Edit: Fixed picture integration
You should if the server is running natively on your Windows.
You might want to enable the remote access (big yellow button at the top of that settings page)
It’s best to enter it as a range (i.e. 192.168.0.0/255.2555.255.0.)
Regarding seeing Unknown IP, try fully shutting down the Plex Server (the program/app, not the device itself, unless you want to) and restarting. That’s fixed that specific thing for me before. Like tom80H said I would also enable remote access, that may be a factor here but I’m not sure because I always have it on.
Thanks so much! I literally just posted a question on this very subject only moments before finding your post.
