I have a VERY strange problem that started a few weeks ago.
Movie trailers will not launch on ANY apple TV client on my network (but the movies themselves play just fine)
I have a plex premium account if it matters for debug, I also tested it signed out of my account and the behavior was the same (to rule out an account setting issue).
I have 4 different clients:
Client #1 - Apple TV 4k running tvOS14.6 / plex 7.17 (1424) - Wired to LAN
Client #2 - Apple TV 4k running tvOS14.6 / plex 7.17 (1424) - Wired to LAN
Client #3 - iPhone 12 Pro max running plex 7.17 - WiFi
Client #4 - Windows PC with firefox web browser connected to plex.tv - Wired to LAN
I have 3 different sources for playing media
Source #1 - Local Plex server 1.23.1.4571 (Synology)
Source #2 - Remote (over internet) Plex Server 1.23.1.4571 (Synology)
Source #3 - Movies & TV (on plex) - To rule out any server side issues
ALL devices/clients can play movies and TV shows with no problems at all from ANY source
The problem is when I go to play a trailer ONLY on ANY AppleTV client the progress/loading icon spins indefinitely while trying to load a trailer while never actually starting playback
I did the following tests:
Test #1 - Attempt to playback trailer from movie on local plex server (on same LAN as appleTV client) - Trailer will not load, progress circle spins indefinitely
Test #2 - Attempt to playback trailer from movie on remote plex server (over internet via appleTV client) - Trailer will not load, progress circle spins indefinitely
Test #3 - Attempt to playback a trailer from âMovies & Shows on Plexâ (ie CRACKLE) - Gives error âSomething went wrong with your media. Please try againâ, yet the movie itself plays fine
Test #4 - Repeat all the above tests on another appleTV unit in same location - Same result. Also deleted and reinstalled the plex App on the appleTV client - same result
Test #5 - Use iphone Plex app on same network - Trailers play fine from all sources (note: iOS is not updated to 14.6 yet, Iâve heard some reports that will break it)
Test #6 - Use web browser on windows PC on same network as the apple TV units - Trailers play fine from all sources.
Test #7 IMPORTANT! - the latest test I did was I found an old AppleTV (pre4k but with touch remote Model A1625) running tvOS 13.3.1 and Plex App v2.13 (14243) and it works PERFECTLY playing trailers on the same network. I had this sitting on a shelf after I updated to AppleTV 4k units, so I figured it was worth testing (and it was!), so now we know the problem is client side on BOTH apple TV 4k units. I also updated plex to latest version 7.17 (1424) and it it still works. So its something on the AppleTV side (either tvOS 14.6 or the 4k unit).
I am completely stumped by this. What i can tell you is that both Apple TV units stopped playing trailers at the same time a few weeks ago (something got an update?) AppleTV 4k units are Model A1842âs running tvOS 14.6 (18L5565a) connected to 1080p displays. I am very suspicious of the tvOS since 18L5565A is a beta 3 version of 14.6.
Looking at the logs the only thing I saw was some type of TLS/SSL error when trying to playback trailer data from a movie hosted on my plex server, and it looked a certificate error when trying to play of âmovies & shows on plexâ.
I attached a copy of the logs so hopefully someone can help figure this out.
I didnât think it would be a client side issue when I have 2 different clients that broke at the same time experiencing the same issue.
It is possible that it might have broke after an AppleTV automatic tvOS update, but I really canât be sure. That would explain two clients experiencing the same issue.
Its hard to believe its a server side issue when I have 2 different plex servers and the problem is also reproducible with âmovies & shows on plexâ (ie CRACKLE).
Its hard to believe its a network/LAN issue if the windows PC and iPhone play back trailers fine.
I feel like Iâve done an exhaustive amount of debugging, and still canât figure it out. Please help me! Thank you
LATEST UPDATE 5/25/21 - I did some more debugging. This seems to be related specifically to AppleTV 4k hardware and tvOS 14.6 and up (14.7 beta also has this issue). I was able to confirm this by having a friend of mine do some debugging and updated his AppleTV unit to the RELEASE (not beta) version of 14.6 today, and his immediately broke with exactly the same problem. I tested on an older AppleTV HD (touch remote pre 4k), and it works fine when updated to 14.6. But on all updated Apple TV 4k units, they have this issue.
Server Version#: 1.23.1.4571 (Synology) - Tested on two different servers & âmovies & shows on plexâ
Player Version#: 7.17 (1424)
Play Trailer from remote plex server.txt (159.4 KB)
Play trailer from movies and shows (on plex).txt (52.7 KB)
