Plex Transcode Quality
Server Version#: 1.14.1.5488
Player Version#: 3.81.1
Hi, i discovered last night that plex is transcoding every single video i have when i play it on my shield app just because of the fact that is using subtitles, if i turn them off then everything is ok, but thats not the main issue, the main one is that when it transcode, videos look kind of pale and greyed out, its like it looses a ■■■■ ton of quality and i havent found a way to revert this, so now im using Kodi for my remote streaming but i very much would like to go back to plex if this has a fix and about the subtitles, i use STR only subs and its suppouse to not transcode when i u se those types of subs, also i have everything on my Shield Plex Client setup to max, even h264 quality set to off :frowning:
i guess no one has an answer? :frowning:
