Plex Transcoder Errors?
Actually, it is set to send it’s logs Settings > advanced > log to media server.
Debug log level
(Persists for 8 hours so last zip was while enabled)
I will go digging but I don’t remember seeing player logs in it.
Standby please
Yeah, I’m SSH’d in, if it’s a separate file it’s at the minimum not dumping it into that same log folder /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Logs
stand by please… I found the samsung log info interspersed … filtering it now
No worries, take all the time you need. I’m around.
  1. PMS starts transcode REMUX for the TV app (normal)
Aug 02, 2023 23:26:54.056 [139796445522744] DEBUG - [Req#4673f/Transcode/dyipmgne48jzr6jsasyqqg08/98ad3695-40e9-4055-9112-ad7fb6ae564a] Transcoder segment range: 434 - 437 (437)
Aug 02, 2023 23:26:54.098 [139796497574712] DEBUG - Request: [192.168.1.231:60745 (Subnet)] POST /log (20 live) #4660a GZIP Signed-in Token (GreggyBear) (TV 2021)
Aug 02, 2023 23:26:54.098 [139796497574712] DEBUG - [Req#4660a] [Plex for Samsung] [GreggyBear:bo83t8cx92f8zjx83re93wvk] [PlaybackSessionController] Setting up player for playback
Aug 02, 2023 23:26:54.098 [139796497574712] DEBUG - [Req#4660a] [Plex for Samsung] [GreggyBear:bo83t8cx92f8zjx83re93wvk] [PlaybackSessionController] Creating player
Aug 02, 2023 23:26:54.098 [139796497574712] DEBUG - [Req#4660a] [Plex for Samsung] [GreggyBear:bo83t8cx92f8zjx83re93wvk] [PlaybackSessionController] Created player
Aug 02, 2023 23:26:54.098 [139796497574712] DEBUG - [Req#4660a] [Plex for Samsung] [GreggyBear:bo83t8cx92f8zjx83re93wvk] [PlaybackSessionController] Set player
Aug 02, 2023 23:26:54.098 [139796497574712] DEBUG - [Req#4660a] [Plex for Samsung] [GreggyBear:bo83t8cx92f8zjx83re93wvk] [PlaybackSessionController] Checking for Ad
Aug 02, 2023 23:26:54.098 [139796497574712] DEBUG - [Req#4660a] [Plex for Samsung] [GreggyBear:bo83t8cx92f8zjx83re93wvk] [PlaybackSessionController] Finished checking for Ad
Aug 02, 2023 23:26:54.098 [139796497574712] INFO - [Req#4660a] [Plex for Samsung] [GreggyBear:bo83t8cx92f8zjx83re93wvk] [PlaybackSessionController] playback state changed to: buffering
Aug 02, 2023 23:26:54.098 [139796497574712] DEBUG - [Req#4660a] [Plex for Samsung] [GreggyBear:bo83t8cx92f8zjx83re93wvk] [PlaybackSessionController] Opening playback
Aug 02, 2023 23:26:54.098 [139796497574712] INFO - [Req#4660a] [Plex for Samsung] [GreggyBear:bo83t8cx92f8zjx83re93wvk] [Subtitles: Controller] Initializing controller
Aug 02, 2023 23:26:54.098 [139796497574712] INFO - [Req#4660a] [Plex for Samsung] [GreggyBear:bo83t8cx92f8zjx83re93wvk] [PlaybackSessionController] playback state changed to: playing
Aug 02, 2023 23:26:54.098 [139796497574712] INFO - [Req#4660a] [Plex for Samsung] [GreggyBear:bo83t8cx92f8zjx83re93wvk] Refreshing playqueue, current item: Final Call
Aug 02, 2023 23:26:54.098 [139796497574712] INFO - [Req#4660a] [Plex for Samsung] [GreggyBear:bo83t8cx92f8zjx83re93wvk] Refreshed/modified playqueue, current item: 543461
Aug 02, 2023 23:26:54.098 [139796497574712] INFO - [Req#4660a] [Plex for Samsung] [GreggyBear:bo83t8cx92f8zjx83re93wvk] [Subtitles: Worker Controller] Worker created.
Aug 02, 2023 23:26:54.098 [139796497574712] INFO - [Req#4660a] [Plex for Samsung] [GreggyBear:bo83t8cx92f8zjx83re93wvk] [Subtitles: Engine] Created Subtitles Engine
Aug 02, 2023 23:26:54.098 [139796497574712] INFO - [Req#4660a] [Plex for Samsung] [GreggyBear:bo83t8cx92f8zjx83re93wvk] [Subtitles: Connection] Received new connection request at offset 2171196
Aug 02, 2023 23:26:54.098 [139796497574712] INFO - [Req#4660a] [Plex for Samsung] [GreggyBear:bo83t8cx92f8zjx83re93wvk] [Subtitles: Connection] Opening connection at offset 2171196
  1. Mid playback it wants to update player info
Aug 02, 2023 23:27:00.452 [139796449741624] INFO - [Req#46789] [Plex for Samsung] [GreggyBear:bo83t8cx92f8zjx83re93wvk] [PlaybackSessionController] playback state changed to: paused
Aug 02, 2023 23:27:00.452 [139796449741624] INFO - [Req#46789] [Plex for Samsung] [GreggyBear:bo83t8cx92f8zjx83re93wvk] [Tizen Continue Watching Updater] Clearing continue watching settings
Aug 02, 2023 23:27:00.452 [139796449741624] INFO - [Req#46789] [Plex for Samsung] [GreggyBear:bo83t8cx92f8zjx83re93wvk] [Tizen Continue Watching Updater] Starting background service.
Aug 02, 2023 23:27:00.452 [139796449741624] INFO - [Req#46789] [Plex for Samsung] [GreggyBear:bo83t8cx92f8zjx83re93wvk] [Tizen Continue Watching Updater] Background service started.
Aug 02, 2023 23:27:00.452 [139796449741624] ERROR - [Req#46789] [Plex for Samsung] [GreggyBear:bo83t8cx92f8zjx83re93wvk] [Tizen Background Service]: Continue Watching: Request error: Error: connect ECONNREFUSED 127.0.0.1:9013
Aug 02, 2023 23:27:00.452 [139796449741624] ERROR - [Req#46789] [Plex for Samsung] [GreggyBear:bo83t8cx92f8zjx83re93wvk] [Tizen Background Service]: Continue Watching: An error has occurred: Error: connect ECONNREFUSED 127.0.0.1:9013
Aug 02, 2023 23:27:00.452 [139796449741624] INFO - [Req#46789] [Plex for Samsung] [GreggyBear:bo83t8cx92f8zjx83re93wvk] [Tizen Background Service]: Continue Watching: Updating Continue Watching data
Aug 02, 2023 23:27:00.452 [139796449741624] INFO - [Req#46789] [Plex for Samsung] [GreggyBear:bo83t8cx92f8zjx83re93wvk] Opening modal: SettingsScreen
Aug 02, 2023 23:27:00.452 [139796449741624] INFO - [Req#46789] [Plex for Samsung] [GreggyBear:bo83t8cx92f8zjx83re93wvk] Opened modal: SettingsScreen
Aug 02, 2023 23:27:00.452 [139796449741624] INFO - [Req#46789] [Plex for Samsung] [GreggyBear:bo83t8cx92f8zjx83re93wvk] [Tizen Continue Watching Updater] Continue Watching service processing request.
  1. Playback just stops – No error messages from either side
Aug 02, 2023 23:27:10.918 [139796497574712] DEBUG - [Req#46876/Transcode/dyipmgne48jzr6jsasyqqg08/98ad3695-40e9-4055-9112-ad7fb6ae564a] Transcoder segment range: 434 - 527 (527)
Aug 02, 2023 23:27:11.097 [139796545047352] DEBUG - [HttpClient/HCl#1d0] HTTP/2.0 (0.3s) 200 response from GET https://plex.tv/updater/products/5/check.xml?build=linux-x86_64&channel=0&distribution=debian&version=1.32.5.7349-8f4248874
Aug 02, 2023 23:27:11.097 [139796396055352] INFO - [Req#46878] AutoUpdate: no updates available
Aug 02, 2023 23:27:11.097 [139796580809528] DEBUG - Completed: [192.168.1.63:50267] 200 PUT /updater/check?download=0 (25 live) #46878 TLS GZIP 344ms 327 bytes (pipelined: 3)
Aug 02, 2023 23:27:11.173 [139796445522744] DEBUG - [Req#4687c/Transcode/dyipmgne48jzr6jsasyqqg08/98ad3695-40e9-4055-9112-ad7fb6ae564a] Transcoder segment range: 434 - 528 (528)
Aug 02, 2023 23:27:11.337 [139796449741624] DEBUG - [Req#46885/Transcode/dyipmgne48jzr6jsasyqqg08/98ad3695-40e9-4055-9112-ad7fb6ae564a] Transcoder segment range: 434 - 529 (529)
Aug 02, 2023 23:27:11.549 [139796400274232] DEBUG - [Req#46888/Transcode/dyipmgne48jzr6jsasyqqg08/98ad3695-40e9-4055-9112-ad7fb6ae564a] Transcoder segment range: 434 - 530 (530)
Aug 02, 2023 23:27:11.556 [139796497574712] DEBUG - Request: [192.168.1.63:50267 (Subnet)] GET /music/iTunes (25 live) #46884 TLS GZIP Signed-in Token (GreggyBear) (Chrome)
Aug 02, 2023 23:27:11.556 [139796580809528] DEBUG - Completed: [192.168.1.63:50267] 404 GET /music/iTunes (25 live) #46884 TLS GZIP 0ms 511 bytes (pipelined: 4)
Aug 02, 2023 23:27:11.562 [139796396055352] DEBUG - Request: [192.168.1.63:50267 (Subnet)] GET /hubs/continueWatching?contentDirectoryID=6%2C5%2C3%2C1%2C4%2C2%2Cplaylists%2C13&includeMeta=1&excludeFields=summary (25 live) #4688c TLS GZIP Signed-in Token (GreggyBear) (Chrome)
Aug 02, 2023 23:27:11.562 [139796396055352] DEBUG - [Req#4688c] HubCache: Adding '1/continueWatching/1/hubs/continueWatching/enexternal-media,indirect-media,hub-style-list/contentDirectoryID=6%2C5%2C3%2C1%2C4%2C2%2Cplaylists%2C13&excludeFields=summary&includeMeta=1' to the cache (1/continueWatching/1/hubs/continueWatching/enexternal-media,indirect-media,hub-style-list/contentDirectoryID=6%2C5%2C3%2C1%2C4%2C2%2Cplaylists%2C13&excludeFields=summary&includeMeta=1).
  1. A bit further down – Transcoder crashes on the REMUX
Aug 02, 2023 23:27:14.063 [139796582918968] DEBUG - Completed: [192.168.1.63:50244] 200 GET /web/chunk-9434-7f0a899023a2d7d6f9a8-plex-4.108.0.32184-ffafb0d.css (28 live) #468b4 GZIP 0ms 72260 bytes (pipelined: 9)
Aug 02, 2023 23:27:14.072 [139796400274232] DEBUG - [Req#468c7/Transcode/dyipmgne48jzr6jsasyqqg08/98ad3695-40e9-4055-9112-ad7fb6ae564a] Transcoder segment range: 434 - 541 (541)
Aug 02, 2023 23:27:14.344 [139796404493112] DEBUG - [Req#468d1/Transcode/dyipmgne48jzr6jsasyqqg08/98ad3695-40e9-4055-9112-ad7fb6ae564a] Transcoder segment range: 434 - 542 (542)
Aug 02, 2023 23:27:14.696 [139796497574712] DEBUG - [Req#468d4/Transcode/dyipmgne48jzr6jsasyqqg08/98ad3695-40e9-4055-9112-ad7fb6ae564a] Transcoder segment range: 434 - 543 (543)
Aug 02, 2023 23:27:15.047 [139796400274232] DEBUG - [Req#468d6/Transcode/dyipmgne48jzr6jsasyqqg08/98ad3695-40e9-4055-9112-ad7fb6ae564a] Transcoder segment range: 434 - 544 (544)
Aug 02, 2023 23:27:15.364 [139796497574712] DEBUG - [Req#468d9/Transcode/dyipmgne48jzr6jsasyqqg08/98ad3695-40e9-4055-9112-ad7fb6ae564a] Transcoder segment range: 434 - 545 (545)
Aug 02, 2023 23:27:15.672 [139796396055352] DEBUG - [Req#468db/Transcode/dyipmgne48jzr6jsasyqqg08/98ad3695-40e9-4055-9112-ad7fb6ae564a] Transcoder segment range: 434 - 546 (546)
Aug 02, 2023 23:27:15.964 [139796449741624] DEBUG - [Req#468df/Transcode/dyipmgne48jzr6jsasyqqg08/98ad3695-40e9-4055-9112-ad7fb6ae564a] Transcoder segment range: 434 - 547 (547)
Aug 02, 2023 23:27:16.319 [139796404493112] DEBUG - [Req#468e2/Transcode/dyipmgne48jzr6jsasyqqg08/98ad3695-40e9-4055-9112-ad7fb6ae564a] Transcoder segment range: 434 - 548 (548)
Aug 02, 2023 23:27:16.614 [139796400274232] DEBUG - [Req#468e4/Transcode/dyipmgne48jzr6jsasyqqg08/98ad3695-40e9-4055-9112-ad7fb6ae564a] Transcoder segment range: 434 - 549 (549)
Aug 02, 2023 23:27:17.260 [139796404493112] DEBUG - [Req#468e7/Transcode/dyipmgne48jzr6jsasyqqg08/98ad3695-40e9-4055-9112-ad7fb6ae564a] Transcoder segment range: 434 - 550 (550)
Aug 02, 2023 23:27:17.624 [139796449741624] DEBUG - [Req#468ea/Transcode/dyipmgne48jzr6jsasyqqg08/98ad3695-40e9-4055-9112-ad7fb6ae564a] Transcoder segment range: 434 - 551 (551)
Aug 02, 2023 23:27:17.686 [139796585499448] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 31040 is -11 (signal: Segmentation fault)
Aug 02, 2023 23:27:17.686 [139796410821432] DEBUG - Notifying consumer that data is complete.
This is DUMB.
Can you get me a copy of that file or the piece up to the point of failure ? (Is it small enough?)
Yeah, I’ll 7z it and send you a link. Password will be your username
Hey bud, figured I’d come back here versus DMs. I assume at this point it’s a “wait for the devs” circumstance?
Yes, it is.
It’s time to get it under the debugger and run it until it faults — Then fix the fault
Haha sounds good bud. Holler if you guys need any testing or whatever.
