Plex tv guide/local tuners issues and missing info
Is there a way to tell which tuner and what the actual channel number being played is from the dashboard? Seems to only show the network but I would like to be able to see which tuner is in use and what channel its tuned to.
Also, I seem to have found a bug with the guide. When the same program is on more than 1 available channel, the guide seems to default to the lowest channel number. So if i decide to record something, I cant tell which channel its actually using to record.
Server Version#:1.85.0.4071-21128b56
Player Version#:Any
