Plex UI not displaying content
Server Version#: plexmediaserver-1.40.4.8679-424562606.x86_64
Player Version#: 4.132.2
Okay, so I have a folder that is not showing up in the Plex UI. I know, I know – follow the proper naming conventions … I’ve seen all those posts too … and this isn’t that … let me explain …
According to my Linux Shell, in the directory “/opt/media/tv.shows” I have 144 folders:
[ PLEX MEDIA SERVER (Red Hat Enterprise Linux release 9.4 (Plow)) ]
[ USER: media ]
[ HOST: plex (10.0.0.20) ]
[ You're in (( /opt/media/tv.shows )) ]
--> ls -Alh | wc -l
144
This pastebin link contains the actual directory listing, and as you’ll see, I am following the proper (suggested) naming conventions.
Despite this, the Plex UI is showing 143 shows. For an unknown reason, its leaving out ‘Star Trek (1966) {tvdb-77526}’, I can’t figure out why.
In order to track down if this was a Plex thing or a Plex UI thing, I took a backup of the database, and then interrogated that offline copy with this Python script … it showed:
--> /opt/projects/plexigator/venv/bin/python /opt/projects/plexigator/plexigator.py
All local folders are recognized by Plex.
All Plex TV shows are present in local folders.
So, Plex sees the folder – but why isn’t it shown in the UI ?!?
I’m really confused, and I would greatly appreciate some help in understanding what’s going on.
This is a screenshot, showing the entire “S” section of the TV Shows library … no “Star Trek” the original series. :frowning:
Here is a screenshot showing the Plex database’s entry for the show.
I appreciate the help, thank you.
Can you please provide the server DEBUG logs ZIP file?
(Settings - Server - Troubleshooting - Download Logs) – attach that ZIP
Plex Media Server Logs_2024-07-13_18-45-18.zip (4.6 MB)
Not sure if this helps, @ChuckPa , but I found these entries in the logs I uploaded:
--> find . -type f -iname "*.log" -exec bash -c "if grep -iq 'Star Trek (1966)' '{}'; then echo MATCHED '{}'; grep -i 'Star Trek (1966)' '{}'; fi;" \;
MATCHED ./Plex Media Server.1.log
Jul 13, 2024 18:21:55.487 [140138051402552] DEBUG - Scanner: Processing directory /opt/media/tv.shows/Star Trek (1966) {tvdb-77526} (parent: yes)
Jul 13, 2024 18:21:55.507 [140138051402552] DEBUG - Skipping over directory 'Star Trek (1966) {tvdb-77526}', as nothing has changed; removing 79 media items from map.
Jul 13, 2024 18:21:56.094 [140138051402552] DEBUG - Updating directory 'Star Trek (1966) {tvdb-77526}' (ID 3219) to time 2023-05-17 16:22:12.
MATCHED ./Plex Media Server.2.log
Jul 13, 2024 17:41:55.684 [140138051402552] DEBUG - Scanner: Processing directory /opt/media/tv.shows/Star Trek (1966) {tvdb-77526} (parent: yes)
Jul 13, 2024 17:41:55.702 [140138051402552] DEBUG - Skipping over directory 'Star Trek (1966) {tvdb-77526}', as nothing has changed; removing 79 media items from map.
Jul 13, 2024 17:41:56.266 [140138051402552] DEBUG - Updating directory 'Star Trek (1966) {tvdb-77526}' (ID 3219) to time 2023-05-17 16:22:12.
Jul 13, 2024 18:01:55.500 [140138051402552] DEBUG - Scanner: Processing directory /opt/media/tv.shows/Star Trek (1966) {tvdb-77526} (parent: yes)
Jul 13, 2024 18:01:55.525 [140138051402552] DEBUG - Skipping over directory 'Star Trek (1966) {tvdb-77526}', as nothing has changed; removing 79 media items from map.
Jul 13, 2024 18:01:56.150 [140138051402552] DEBUG - Updating directory 'Star Trek (1966) {tvdb-77526}' (ID 3219) to time 2023-05-17 16:22:12.
MATCHED ./Plex Media Server.3.log
Jul 13, 2024 16:21:56.228 [140138051402552] DEBUG - Scanner: Processing directory /opt/media/tv.shows/Star Trek (1966) {tvdb-77526} (parent: yes)
Jul 13, 2024 16:21:56.248 [140138051402552] DEBUG - Skipping over directory 'Star Trek (1966) {tvdb-77526}', as nothing has changed; removing 79 media items from map.
Jul 13, 2024 16:21:56.925 [140138051402552] DEBUG - Updating directory 'Star Trek (1966) {tvdb-77526}' (ID 3219) to time 2023-05-17 16:22:12.
Jul 13, 2024 16:41:55.737 [140138051402552] DEBUG - Scanner: Processing directory /opt/media/tv.shows/Star Trek (1966) {tvdb-77526} (parent: yes)
Jul 13, 2024 16:41:55.754 [140138051402552] DEBUG - Skipping over directory 'Star Trek (1966) {tvdb-77526}', as nothing has changed; removing 79 media items from map.
Jul 13, 2024 16:41:56.339 [140138051402552] DEBUG - Updating directory 'Star Trek (1966) {tvdb-77526}' (ID 3219) to time 2023-05-17 16:22:12.
Jul 13, 2024 17:01:55.586 [140138051402552] DEBUG - Scanner: Processing directory /opt/media/tv.shows/Star Trek (1966) {tvdb-77526} (parent: yes)
Jul 13, 2024 17:01:55.604 [140138051402552] DEBUG - Skipping over directory 'Star Trek (1966) {tvdb-77526}', as nothing has changed; removing 79 media items from map.
Jul 13, 2024 17:01:56.174 [140138051402552] DEBUG - Updating directory 'Star Trek (1966) {tvdb-77526}' (ID 3219) to time 2023-05-17 16:22:12.
Jul 13, 2024 17:21:55.444 [140138051402552] DEBUG - Scanner: Processing directory /opt/media/tv.shows/Star Trek (1966) {tvdb-77526} (parent: yes)
Jul 13, 2024 17:21:55.465 [140138051402552] DEBUG - Skipping over directory 'Star Trek (1966) {tvdb-77526}', as nothing has changed; removing 79 media items from map.
Jul 13, 2024 17:21:56.043 [140138051402552] DEBUG - Updating directory 'Star Trek (1966) {tvdb-77526}' (ID 3219) to time 2023-05-17 16:22:12.
MATCHED ./Plex Media Server.4.log
Jul 13, 2024 16:01:55.815 [140138051402552] DEBUG - Scanner: Processing directory /opt/media/tv.shows/Star Trek (1966) {tvdb-77526} (parent: yes)
Jul 13, 2024 16:01:55.835 [140138051402552] DEBUG - Skipping over directory 'Star Trek (1966) {tvdb-77526}', as nothing has changed; removing 79 media items from map.
Jul 13, 2024 16:01:56.399 [140138051402552] DEBUG - Updating directory 'Star Trek (1966) {tvdb-77526}' (ID 3219) to time 2023-05-17 16:22:12.
MATCHED ./Plex Media Server.5.log
Jul 13, 2024 15:01:55.507 [140138051402552] DEBUG - Scanner: Processing directory /opt/media/tv.shows/Star Trek (1966) {tvdb-77526} (parent: yes)
Jul 13, 2024 15:01:55.524 [140138051402552] DEBUG - Skipping over directory 'Star Trek (1966) {tvdb-77526}', as nothing has changed; removing 79 media items from map.
Jul 13, 2024 15:01:56.110 [140138051402552] DEBUG - Updating directory 'Star Trek (1966) {tvdb-77526}' (ID 3219) to time 2023-05-17 16:22:12.
Jul 13, 2024 15:21:55.733 [140138051402552] DEBUG - Scanner: Processing directory /opt/media/tv.shows/Star Trek (1966) {tvdb-77526} (parent: yes)
Jul 13, 2024 15:21:55.749 [140138051402552] DEBUG - Skipping over directory 'Star Trek (1966) {tvdb-77526}', as nothing has changed; removing 79 media items from map.
Jul 13, 2024 15:21:56.339 [140138051402552] DEBUG - Updating directory 'Star Trek (1966) {tvdb-77526}' (ID 3219) to time 2023-05-17 16:22:12.
Jul 13, 2024 15:41:55.641 [140138051402552] DEBUG - Scanner: Processing directory /opt/media/tv.shows/Star Trek (1966) {tvdb-77526} (parent: yes)
Jul 13, 2024 15:41:55.669 [140138051402552] DEBUG - Skipping over directory 'Star Trek (1966) {tvdb-77526}', as nothing has changed; removing 79 media items from map.
Jul 13, 2024 15:41:56.312 [140138051402552] DEBUG - Updating directory 'Star Trek (1966) {tvdb-77526}' (ID 3219) to time 2023-05-17 16:22:12.
MATCHED ./Plex Media Server.log
Jul 13, 2024 18:41:55.953 [140138051402552] DEBUG - Scanner: Processing directory /opt/media/tv.shows/Star Trek (1966) {tvdb-77526} (parent: yes)
Jul 13, 2024 18:41:55.972 [140138051402552] DEBUG - Skipping over directory 'Star Trek (1966) {tvdb-77526}', as nothing has changed; removing 79 media items from map.
Jul 13, 2024 18:41:56.600 [140138051402552] DEBUG - Updating directory 'Star Trek (1966) {tvdb-77526}' (ID 3219) to time 2023-05-17 16:22:12.
More proof that it sees the show. Now I’m even more confused.
Set the library display mode to “Episodes”.
Then enable the Duplicates filter. Are there any? If so, look at the plex media info of them.
Do also check if there are Collections in your tv show library.
If for instance, you have both the original series and TNG, and they have been added into the same collection, you might not see a poster for each.
A quick test for this is to change the sorting order of the library from Title to something else, then look at the item count.
Additional info:
There are 79 episodes across Seasons 1-3. Below also find my file naming.
[chuck@lizum ~.2000]$ cd /glock/media/tv2/Star\ Trek/
[chuck@lizum Star Trek.2001]$ ls -la
total 24
drwxrwxr-x  6 chuck chuck   93 Apr 26  2022 ./
drwxrwxr-x 91 chuck chuck 8192 Jul  9 02:05 ../
drwxrwxr-x  2 chuck chuck 4096 Apr 26  2022 Season 01/
drwxrwxr-x  2 chuck chuck 4096 Apr 26  2022 Season 02/
drwxrwxr-x  2 chuck chuck 4096 Apr 26  2022 Season 03/
drwxrwxr-x  2 chuck chuck   72 Nov  1  2021 Specials/
[chuck@lizum Star Trek.2002]$ find ./Season* -type f -print | wc -l
79
[chuck@lizum Star Trek.2003]$ ll *01
total 142857588
drwxrwxr-x 2 chuck chuck       4096 Apr 26  2022 ./
drwxrwxr-x 6 chuck chuck         93 Apr 26  2022 ../
-rw-r--r-- 1 chuck chuck 7799832967 Apr 26  2022 Star Trek - S01E01 - The Man Trap.mkv
-rw-r--r-- 1 chuck chuck 4794914310 Apr 26  2022 Star Trek - S01E02 - Charlie X.mkv
-rw-r--r-- 1 chuck chuck 7827197100 Apr 26  2022 Star Trek - S01E03 - Where No Man Has Gone Before.mkv
-rw-r--r-- 1 chuck chuck 4931438886 Apr 26  2022 Star Trek - S01E04 - The Naked Time.mkv
-rw-r--r-- 1 chuck chuck 5100598472 Apr 26  2022 Star Trek - S01E05 - The Enemy Within.mkv
-rw-r--r-- 1 chuck chuck 7098832550 Apr 26  2022 Star Trek - S01E06 - Mudd's Women.mkv
-rw-r--r-- 1 chuck chuck 4473766214 Apr 26  2022 Star Trek - S01E07 - What Are Little Girls Made Of.mkv
-rw-r--r-- 1 chuck chuck 4473899283 Apr 26  2022 Star Trek - S01E08 - Miri.mkv
-rw-r--r-- 1 chuck chuck 4261595082 Apr 26  2022 Star Trek - S01E09 - Dagger of the Mind.mkv
-rw-r--r-- 1 chuck chuck 4574462993 Apr 26  2022 Star Trek - S01E10 - The Corbomite Maneuver.mkv
-rw-r--r-- 1 chuck chuck 4454802067 Apr 26  2022 Star Trek - S01E11 - The Menagerie (1).mkv
-rw-r--r-- 1 chuck chuck 4557501791 Apr 26  2022 Star Trek - S01E12 - The Menagerie (2).mkv
-rw-r--r-- 1 chuck chuck 4666750481 Apr 26  2022 Star Trek - S01E13 - The Conscience of the King.mkv
-rw-r--r-- 1 chuck chuck 4799351008 Apr 26  2022 Star Trek - S01E14 - Balance of Terror.mkv
-rw-r--r-- 1 chuck chuck 4251419549 Apr 26  2022 Star Trek - S01E15 - Shore Leave.mkv
-rw-r--r-- 1 chuck chuck 4994042567 Apr 26  2022 Star Trek - S01E16 - The Galileo Seven.mkv
-rw-r--r-- 1 chuck chuck 4865260939 Apr 26  2022 Star Trek - S01E17 - The Squire of Gothos.mkv
-rw-r--r-- 1 chuck chuck 4253252515 Apr 26  2022 Star Trek - S01E18 - Arena.mkv
-rw-r--r-- 1 chuck chuck 4718225722 Apr 26  2022 Star Trek - S01E19 - Tomorrow is Yesterday.mkv
-rw-r--r-- 1 chuck chuck 7869125077 Apr 26  2022 Star Trek - S01E20 - Court Martial.mkv
-rw-r--r-- 1 chuck chuck 4672201613 Apr 26  2022 Star Trek - S01E21 - The Return of the Archons.mkv
-rw-r--r-- 1 chuck chuck 4944937035 Apr 26  2022 Star Trek - S01E22 - Space Seed.mkv
-rw-r--r-- 1 chuck chuck 4594182194 Apr 26  2022 Star Trek - S01E23 - A Taste of Armageddon.mkv
-rw-r--r-- 1 chuck chuck 5033264386 Apr 26  2022 Star Trek - S01E24 - This Side of Paradise.mkv
-rw-r--r-- 1 chuck chuck 4261298471 Apr 26  2022 Star Trek - S01E25 - The Devil in the Dark.mkv
-rw-r--r-- 1 chuck chuck 4711470524 Apr 26  2022 Star Trek - S01E26 - Errand of Mercy.mkv
-rw-r--r-- 1 chuck chuck 4253974762 Apr 26  2022 Star Trek - S01E27 - The Alternative Factor.mkv
-rw-r--r-- 1 chuck chuck 4785923290 Apr 26  2022 Star Trek - S01E28 - The City on the Edge of Forever.mkv
-rw-r--r-- 1 chuck chuck 4262571382 Apr 26  2022 Star Trek - S01E29 - Operation - Annihilate!.mkv
[chuck@lizum Star Trek.2004]$
Have you done a proper Plex Dance of the series ?
This issue is resolved … although I don’t know why …
I moved the folder outside the library, re-scanned, emptied trash, and set the library to “Hide Collections, but display their items”. I emptied bundled and optimized the database.
I moved the folder back in and upon the automatic re-scan it immediately showed up.
Why?
