Plex Unable to Match Correctly
Example: https://youtu.be/gyiR3Z90SAA
There are the 1971 Andromeda Strain movie and the 2008 remake by the SciFi channel. When I try to match 2008 one, it shows the right one in the menu, but then when clicking match, it merges with the 1971 version and screws up the match. You can see this in the video posted.
Server Version#: 1.21.1.3876
Player Version#: Web Player
Fixed by upgrading Plex library’s matching from legacy.
Are you using the new Plex Movie agent? If so, add the IMDB or TMDB ID to the folder and file name.
/The Andromeda Strain (2008) {imdb-tt0424600}/The Andromeda Strain (2008) {imdb-tt0424600}.mkv
See:
Thanks for the reply, found my fix. :slight_smile:
Yeah. We posted at the same time. Glad you have it working. :slight_smile:
