Unable to match and movies
I saw some older threads that were locked so maybe i missed the solution… i reinstalled to the newest version for my windows server.
I tried manage/ library/upgrade matching and that errors out
I tried changing the order of the movie database to move local and plex legacy to the bottom
I am unable to match any movies.
the movies play fine though.
it doesnt matter if its a movie that was already loaded and i try fix match or a new movie i just loaded and click match… they all fail…
So I guess posting got me to thinking correctly… the scanner and the agent were pointing at the legacy stuff once i changed those to plex movie i was able to apply the upgrade matching and then i could choose plex movie in the fix match and suddenly dozens of movies fixed themselves… hurray
FYI, with the new Plex Movie agent you can add IMDB or TMDB IDs to the folder and file name.
Plex uses the ID first when trying to match movies. So, if you’ve one that won’t match, add the IMDB/TMDB ID to the folder/file name and refresh the metadata. It should match right away.
