Plex Updates Failing
Server Version#: Synology DS920+
Player Version#: Plex v1.23.5.4862
The last update I’ve been able to install successfully was v1.23.5.4862
Since then, all updates that have been released - once installed Plex Server is either unreachable or media is inaccessible. I’ve had to revert back to the 1.23.5.4862 in order to be able to use this with no issues.
Any known issues with the updated releases and Synology?
see attached…Plex Media Server Logs_2021-10-13_07-34-19.zip (2.1 MB)
I performed this step, rebooted the NAS and installed the newest release 1.24.4.5081 and it is still doing the same thing. As soon as I installed this version, the Plex server was inaccessible…
I reinstalled 1.23.5.4862 and the server is still inaccessible…
reverted the bonded ethernet connection setting as mentioned in your post and restarted NAS again. Now I’m able to access the Plex server again.
attaching logs for your review…
Plex Media Server Logs_2021-10-13_08-20-54.zip (1.2 MB)
completed all steps (with exception of #1 - after setting up the bonded connection was unable to access PLEX with URL)
after getting to step 6 after waiting 3 minutes, am able to get to the Plex Server but seeing insecure connection errors and can’t get to those libraries…
also attaching logs …
Plex Media Server Logs_2021-10-13_09-46-36.zip (1.0 MB)
everything seems to be working fine now.
Thanks!
