Server Version#: Version 1.18.0.1913
Player Version#:6.4
Oct 09, 2019 18:48:55.762 [3612] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:48:55.809 [3652] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:48:58.282 [2952] Error — Unable to find title for item of type 5
Oct 09, 2019 18:48:58.284 [2952] Error — Unable to find title for item of type 5
Oct 09, 2019 18:48:59.905 [4880] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:48:59.952 [3652] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:51:26.761 [4880] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:51:27.011 [3652] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:51:34.469 [0952] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:51:34.672 [2028] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:51:35.353 [4120] Error — Unable to find title for item of type 5
Oct 09, 2019 18:52:11.269 [3652] Error — [Transcoder] [h264 @ 02e91680] co located POCs unavailable
Oct 09, 2019 18:52:21.215 [5908] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:52:21.417 [1568] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:52:33.345 [5916] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:52:33.517 [4864] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:52:35.971 [5908] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:52:36.090 [3612] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:52:36.505 [3528] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:52:36.713 [5908] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:52:46.875 [4880] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:52:46.922 [3652] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:52:50.079 [4864] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:52:50.173 [2036] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:52:51.269 [2964] Error — Unable to find title for item of type 5
Oct 09, 2019 18:52:51.271 [2964] Error — Unable to find title for item of type 5
Oct 09, 2019 18:52:52.146 [4864] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:52:52.334 [4864] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:52:53.490 [4576] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:52:53.740 [2028] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:52:56.097 [3652] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:52:56.333 [5908] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:53:00.127 [3612] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:53:00.451 [2036] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:53:05.371 [5928] Error — DVR:Recorder: Failed to remove directory E:\Transcoder\Transcode\Sessions\plex-transcode-48c0853b-a549-4c91-b137-1ed1770b9aad\media-00000.ts
Oct 09, 2019 18:53:10.725 [3528] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:53:10.772 [3612] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:53:11.650 [3244] Error — Unable to find title for item of type 5
Oct 09, 2019 18:53:37.269 [3244] Error — Failed to start session.
Oct 09, 2019 18:53:37.269 [3244] Error — DVR:Recorder: Unable to create transcode session or session failed to start.
Oct 09, 2019 18:53:37.316 [3244] Error — DVR:Recorder: Error 16 (Recording failed. Please check your tuner or antenna.) starting the record, shutting things down.
Oct 09, 2019 18:53:37.316 [5908] Error — DVR:Subscription: Rolling media grab failed to start.
Oct 09, 2019 18:53:37.332 [3244] Error — DVR:Grabber: Starting media grab failed.
Oct 09, 2019 18:53:37.332 [3244] Error — Unknown metadata type:
Oct 09, 2019 18:53:37.730 [3244] Error — Unable to find title for item of type 5
Oct 09, 2019 18:53:37.746 [3244] Error — Unable to find title for item of type 5
Oct 09, 2019 18:53:39.491 [4880] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:53:39.538 [3612] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:53:53.787 [4880] Error — Unknown metadata type: folder
Oct 09, 2019 18:54:51.874 [3244] Error — Unable to find title for item of type 5
Oct 09, 2019 18:54:53.870 [1568] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:54:54.105 [5908] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:55:08.442 [5908] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:55:08.598 [2036] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:55:13.020 [3612] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:55:13.213 [5916] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:55:14.801 [4576] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:55:14.926 [4576] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:55:19.175 [5908] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:55:19.345 [4864] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:55:21.439 [3652] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:55:21.579 [4880] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:55:30.180 [2028] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:55:30.384 [4880] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:55:30.743 [3528] Error — [Transcoder] [aac @ 02f41700] Number of bands (61) exceeds limit (46).
Oct 09, 2019 18:55:30.774 [4880] Error — [Transcoder] Error while decoding stream #0:1: Invalid data found when processing input
Oct 09, 2019 18:55:30.774 [5908] Error — [Transcoder] [aac @ 02f41700] channel element 2.1 is not allocated
Oct 09, 2019 18:55:30.774 [2036] Error — [Transcoder] Error while decoding stream #0:1: Invalid data found when processing input
Oct 09, 2019 18:55:31.355 [2964] Error — Unable to find title for item of type 5
Oct 09, 2019 18:56:08.994 [2036] Error — [Transcoder] [h264 @ 02ddb100] error while decoding MB 29 3, bytestream -7
Oct 09, 2019 18:57:22.081 [5908] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:57:22.347 [3528] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:58:09.560 [2036] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:58:09.747 [1568] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:58:11.590 [2036] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:58:11.793 [3344] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:58:23.137 [1568] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:58:23.293 [4864] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:58:25.340 [2028] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:58:25.528 [3528] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:58:27.525 [4880] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:58:27.666 [4576] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:58:28.307 [5916] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:58:28.447 [5908] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:58:30.595 [2036] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:58:30.736 [4864] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:58:32.158 [2036] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:58:32.298 [5908] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:58:35.116 [3652] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:58:35.257 [3528] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:58:36.307 [4576] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:58:36.427 [5916] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:58:36.577 [4864] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:58:36.844 [3612] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:58:38.565 [2036] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:58:38.706 [3344] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:58:39.552 [2036] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:58:39.709 [4864] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:58:41.147 [3652] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:58:41.303 [3528] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:58:42.153 [2036] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:58:42.293 [5916] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:58:44.546 [3612] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:58:44.704 [2028] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:58:45.079 [4880] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:58:45.220 [4864] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:58:46.742 [1568] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:58:46.930 [3652] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:58:48.133 [4576] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:58:48.274 [3652] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:58:50.777 [3528] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:58:50.981 [5908] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:58:52.219 [3612] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:58:52.360 [4864] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:58:57.000 [4864] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:58:57.156 [1568] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:58:57.847 [5800] Error — Unable to find title for item of type 5
Oct 09, 2019 18:59:08.905 [3344] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:59:09.108 [4576] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:59:14.309 [3612] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:59:14.559 [5908] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:59:23.895 [3612] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:59:24.129 [5908] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:59:26.962 [4576] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:59:27.227 [4880] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:59:31.853 [4880] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:59:32.103 [3528] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:59:37.308 [5908] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:59:37.496 [4864] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 18:59:37.699 [5916] Error — [Transcoder] http://127.0.0.1:32400/livetv/sessions/a60c7141-aa27-42c5-b69a-8b83e0ce991c/6131cf6d26d26b814c9461354d1c513a/index.m3u8?offset=34.000000&X-Plex-Incomplete-Segments=1&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx: Server returned 404 Not Found
Oct 09, 2019 18:59:37.714 [2036] Error — Failed to start session.
Oct 09, 2019 18:59:38.246 [3244] Error — PlexClient::downloadContainer: expected MediaContainer element, found html
Oct 09, 2019 19:00:04.023 [4576] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:00:04.179 [2028] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:00:05.183 [4120] Error — Unable to find title for item of type 5
Oct 09, 2019 19:00:13.765 [3344] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:00:13.952 [2028] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:00:29.212 [3612] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:00:29.388 [5908] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:00:30.625 [4120] Error — Unable to find title for item of type 5
Oct 09, 2019 19:00:48.910 [3344] Error — [Transcoder] [h264 @ 037e3580] co located POCs unavailable
Oct 09, 2019 19:01:12.092 [5908] Error — [Transcoder] [h264 @ 037e0d40] co located POCs unavailable
Oct 09, 2019 19:01:15.043 [2036] Error — [Transcoder] http://127.0.0.1:32400/livetv/sessions/755f28bd-c963-4a4d-8447-5ce0ee8c262a/6131cf6d26d26b814c9461354d1c513a/index.m3u8?offset=62.000000&X-Plex-Incomplete-Segments=1&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx: Server returned 404 Not Found
Oct 09, 2019 19:01:15.059 [3344] Error — Failed to start session.
Oct 09, 2019 19:01:34.120 [3652] Error — [Transcoder] [h264 @ 037e2580] reference picture missing during reorder
Oct 09, 2019 19:01:34.120 [2036] Error — [Transcoder] [h264 @ 037e2580] Missing reference picture, default is 65738
Oct 09, 2019 19:01:37.952 [1568] Error — [Transcoder] [h264 @ 037e2580] reference picture missing during reorder
Oct 09, 2019 19:01:37.952 [2036] Error — [Transcoder] [h264 @ 037e2580] Missing reference picture, default is 65654
Oct 09, 2019 19:01:37.952 [5908] Error — [Transcoder] [h264 @ 037e1940] co located POCs unavailable
Oct 09, 2019 19:01:45.784 [3528] Error — [Transcoder] [h264 @ 037e0d40] co located POCs unavailable
Oct 09, 2019 19:01:46.580 [3612] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:01:46.721 [3652] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:01:47.526 [3280] Error — Unable to find title for item of type 5
Oct 09, 2019 19:02:15.797 [3652] Error — PlexClient::downloadContainer: expected MediaContainer element, found html
Oct 09, 2019 19:02:15.797 [3652] Error — TranscodeUniversalRequest: unable to get container: /livetv/sessions/d07d01eb-4b7e-4c26-b69a-4fb258856197?includeBandwidths=1&offset=0&X-Plex-Client-Capabilities=videoDecoders%3Dh264%7Bprofile%3Ahigh%26resolution%3A1080%26level%3D41%7D;audioDecoders%3Daac%7Bchannels%3A2%7D&X-Plex-Incomplete-Segments=1&X-Plex-Session-Identifier=6131cf6d26d26b814c9461354d1c513a
Oct 09, 2019 19:02:16.016 [3612] Error — PlexClient::downloadContainer: expected MediaContainer element, found html
Oct 09, 2019 19:02:16.016 [3612] Error — TranscodeUniversalRequest: unable to get container: /livetv/sessions/d07d01eb-4b7e-4c26-b69a-4fb258856197?includeBandwidths=1&offset=22&X-Plex-Client-Capabilities=videoDecoders%3Dh264%7Bprofile%3Ahigh%26resolution%3A1080%26level%3D41%7D;audioDecoders%3Daac%7Bchannels%3A2%7D&X-Plex-Incomplete-Segments=1&X-Plex-Session-Identifier=6131cf6d26d26b814c9461354d1c513a
Oct 09, 2019 19:02:16.797 [4120] Error — PlexClient::downloadContainer: expected MediaContainer element, found html
Oct 09, 2019 19:02:16.984 [3612] Error — PlexClient::downloadContainer: expected MediaContainer element, found html
Oct 09, 2019 19:02:16.984 [3612] Error — TranscodeUniversalRequest: unable to get container: /livetv/sessions/d07d01eb-4b7e-4c26-b69a-4fb258856197?includeBandwidths=1&offset=0&X-Plex-Client-Capabilities=videoDecoders%3Dh264%7Bprofile%3Ahigh%26resolution%3A1080%26level%3D41%7D;audioDecoders%3Daac%7Bchannels%3A2%7D&X-Plex-Incomplete-Segments=1&X-Plex-Session-Identifier=6131cf6d26d26b814c9461354d1c513a
Oct 09, 2019 19:02:17.343 [4576] Error — PlexClient::downloadContainer: expected MediaContainer element, found html
Oct 09, 2019 19:02:17.343 [4576] Error — TranscodeUniversalRequest: unable to get container: /livetv/sessions/d07d01eb-4b7e-4c26-b69a-4fb258856197?includeBandwidths=1&offset=22&X-Plex-Client-Capabilities=videoDecoders%3Dh264%7Bprofile%3Ahigh%26resolution%3A1080%26level%3D41%7D;audioDecoders%3Daac%7Bchannels%3A2%7D&X-Plex-Incomplete-Segments=1&X-Plex-Session-Identifier=6131cf6d26d26b814c9461354d1c513a
Oct 09, 2019 19:02:18.094 [4576] Error — PlexClient::downloadContainer: expected MediaContainer element, found html
Oct 09, 2019 19:02:18.094 [4576] Error — TranscodeUniversalRequest: unable to get container: /livetv/sessions/d07d01eb-4b7e-4c26-b69a-4fb258856197?includeBandwidths=1&offset=0&X-Plex-Client-Capabilities=videoDecoders%3Dh264%7Bprofile%3Ahigh%26resolution%3A1080%26level%3D41%7D;audioDecoders%3Daac%7Bchannels%3A2%7D&X-Plex-Incomplete-Segments=1&X-Plex-Session-Identifier=6131cf6d26d26b814c9461354d1c513a
Oct 09, 2019 19:02:18.706 [2028] Error — PlexClient::downloadContainer: expected MediaContainer element, found html
Oct 09, 2019 19:02:18.706 [2028] Error — TranscodeUniversalRequest: unable to get container: /livetv/sessions/d07d01eb-4b7e-4c26-b69a-4fb258856197?includeBandwidths=1&offset=22&X-Plex-Client-Capabilities=videoDecoders%3Dh264%7Bprofile%3Ahigh%26resolution%3A1080%26level%3D41%7D;audioDecoders%3Daac%7Bchannels%3A2%7D&X-Plex-Incomplete-Segments=1&X-Plex-Session-Identifier=6131cf6d26d26b814c9461354d1c513a
Oct 09, 2019 19:02:28.258 [3652] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:02:28.414 [3528] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:02:29.497 [3740] Error — Unable to find title for item of type 5
Oct 09, 2019 19:02:29.499 [3740] Error — Unable to find title for item of type 5
Oct 09, 2019 19:02:29.499 [4120] Error — Unable to find title for item of type 5
Oct 09, 2019 19:02:30.548 [4864] Error — [Transcoder] [h264 @ 037e3580] reference picture missing during reorder
Oct 09, 2019 19:02:30.548 [4880] Error — [Transcoder] [h264 @ 037e3580] reference picture missing during reorder
Oct 09, 2019 19:02:30.548 [0952] Error — [Transcoder] [h264 @ 037e3580] Missing reference picture, default is 65546
Oct 09, 2019 19:02:30.548 [1568] Error — [Transcoder] [h264 @ 037e3580] Missing reference picture, default is 65546
Oct 09, 2019 19:02:30.564 [2028] Error — [Transcoder] [h264 @ 037e0d40] reference picture missing during reorder
Oct 09, 2019 19:02:30.564 [4864] Error — [Transcoder] [h264 @ 037e0d40] Missing reference picture, default is 65554
Oct 09, 2019 19:02:30.564 [4880] Error — [Transcoder] [h264 @ 037e2180] mmco: unref short failure
Oct 09, 2019 19:02:43.797 [2028] Error — PlexClient::downloadContainer: expected MediaContainer element, found html
Oct 09, 2019 19:02:43.797 [2028] Error — TranscodeUniversalRequest: unable to get container: /livetv/sessions/bf276157-e75f-44bd-b66f-9baf910b1fcf?includeBandwidths=1&offset=0&X-Plex-Client-Capabilities=videoDecoders%3Dh264%7Bprofile%3Ahigh%26resolution%3A1080%26level%3D41%7D;audioDecoders%3Daac%7Bchannels%3A2%7D&X-Plex-Incomplete-Segments=1&X-Plex-Session-Identifier=6131cf6d26d26b814c9461354d1c513a
Oct 09, 2019 19:02:44.063 [2028] Error — PlexClient::downloadContainer: expected MediaContainer element, found html
Oct 09, 2019 19:02:44.079 [2028] Error — TranscodeUniversalRequest: unable to get container: /livetv/sessions/bf276157-e75f-44bd-b66f-9baf910b1fcf?includeBandwidths=1&offset=8&X-Plex-Client-Capabilities=videoDecoders%3Dh264%7Bprofile%3Ahigh%26resolution%3A1080%26level%3D41%7D;audioDecoders%3Daac%7Bchannels%3A2%7D&X-Plex-Incomplete-Segments=1&X-Plex-Session-Identifier=6131cf6d26d26b814c9461354d1c513a
Oct 09, 2019 19:02:45.063 [4864] Error — PlexClient::downloadContainer: expected MediaContainer element, found html
Oct 09, 2019 19:02:45.063 [4864] Error — TranscodeUniversalRequest: unable to get container: /livetv/sessions/bf276157-e75f-44bd-b66f-9baf910b1fcf?includeBandwidths=1&offset=0&X-Plex-Client-Capabilities=videoDecoders%3Dh264%7Bprofile%3Ahigh%26resolution%3A1080%26level%3D41%7D;audioDecoders%3Daac%7Bchannels%3A2%7D&X-Plex-Incomplete-Segments=1&X-Plex-Session-Identifier=6131cf6d26d26b814c9461354d1c513a
Oct 09, 2019 19:02:45.366 [4864] Error — PlexClient::downloadContainer: expected MediaContainer element, found html
Oct 09, 2019 19:02:45.366 [4864] Error — TranscodeUniversalRequest: unable to get container: /livetv/sessions/bf276157-e75f-44bd-b66f-9baf910b1fcf?includeBandwidths=1&offset=8&X-Plex-Client-Capabilities=videoDecoders%3Dh264%7Bprofile%3Ahigh%26resolution%3A1080%26level%3D41%7D;audioDecoders%3Daac%7Bchannels%3A2%7D&X-Plex-Incomplete-Segments=1&X-Plex-Session-Identifier=6131cf6d26d26b814c9461354d1c513a
Oct 09, 2019 19:02:46.101 [3528] Error — PlexClient::downloadContainer: expected MediaContainer element, found html
Oct 09, 2019 19:02:46.101 [3528] Error — TranscodeUniversalRequest: unable to get container: /livetv/sessions/bf276157-e75f-44bd-b66f-9baf910b1fcf?includeBandwidths=1&offset=0&X-Plex-Client-Capabilities=videoDecoders%3Dh264%7Bprofile%3Ahigh%26resolution%3A1080%26level%3D41%7D;audioDecoders%3Daac%7Bchannels%3A2%7D&X-Plex-Incomplete-Segments=1&X-Plex-Session-Identifier=6131cf6d26d26b814c9461354d1c513a
Oct 09, 2019 19:02:46.386 [3612] Error — PlexClient::downloadContainer: expected MediaContainer element, found html
Oct 09, 2019 19:02:46.386 [3612] Error — TranscodeUniversalRequest: unable to get container: /livetv/sessions/bf276157-e75f-44bd-b66f-9baf910b1fcf?includeBandwidths=1&offset=8&X-Plex-Client-Capabilities=videoDecoders%3Dh264%7Bprofile%3Ahigh%26resolution%3A1080%26level%3D41%7D;audioDecoders%3Daac%7Bchannels%3A2%7D&X-Plex-Incomplete-Segments=1&X-Plex-Session-Identifier=6131cf6d26d26b814c9461354d1c513a
Oct 09, 2019 19:02:47.096 [3244] Error — PlexClient::downloadContainer: expected MediaContainer element, found html
Oct 09, 2019 19:02:47.112 [2964] Error — PlexClient::downloadContainer: expected MediaContainer element, found html
Oct 09, 2019 19:02:51.782 [4576] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:02:51.938 [2036] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:02:52.985 [2628] Error — Unable to find title for item of type 5
Oct 09, 2019 19:02:52.987 [2628] Error — Unable to find title for item of type 5
Oct 09, 2019 19:03:16.905 [3652] Error — [Transcoder] [h264 @ 037e2180] error while decoding MB 44 31, bytestream -16
Oct 09, 2019 19:03:20.647 [0952] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:03:20.975 [0952] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:03:21.311 [5908] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:03:21.468 [3528] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:03:23.921 [3612] Error — [Transcoder] [h264 @ 037e2180] co located POCs unavailable
Oct 09, 2019 19:03:24.678 [3652] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:03:24.882 [3612] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:03:26.279 [3612] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:03:26.524 [4864] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:03:28.519 [4880] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:03:28.659 [3652] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:03:28.738 [2036] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:03:28.894 [2028] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:03:30.050 [3528] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:03:30.269 [2036] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:03:31.075 [2028] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:03:31.216 [4864] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:03:31.435 [2036] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:03:31.731 [3344] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:03:32.450 [4576] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:03:32.794 [5908] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:03:36.041 [0952] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:03:36.253 [5908] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:03:39.698 [3612] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:03:39.839 [0952] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:03:40.858 [3824] Error — Unable to find title for item of type 5
Oct 09, 2019 19:03:41.714 [0952] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:03:41.917 [1568] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:03:46.585 [0952] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:03:46.778 [4864] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:03:50.137 [0952] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:03:50.340 [3652] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:03:52.753 [5908] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:03:52.955 [2028] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:03:53.870 [5128] Error — Unable to find title for item of type 5
Oct 09, 2019 19:03:54.322 [4576] Error — [Transcoder] http://192.168.1.124:34400/stream/d466742f6f99bb221c9142419bd38dd1: Server returned 403 Forbidden (access denied)
Oct 09, 2019 19:03:54.322 [5128] Error — Failed to start session.
Oct 09, 2019 19:03:54.322 [5128] Error — DVR:Recorder: Unable to create transcode session or session failed to start.
Oct 09, 2019 19:03:54.322 [5128] Error — DVR:Recorder: Error 16 (Recording failed. Please check your tuner or antenna.) starting the record, shutting things down.
Oct 09, 2019 19:03:54.322 [4864] Error — DVR:Subscription: Rolling media grab failed to start.
Oct 09, 2019 19:03:54.338 [5128] Error — DVR:Grabber: Starting media grab failed.
Oct 09, 2019 19:03:54.338 [5128] Error — Unknown metadata type:
Oct 09, 2019 19:04:00.451 [4880] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:04:00.654 [3528] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:04:01.340 [5804] Error — Unable to find title for item of type 5
Oct 09, 2019 19:04:24.725 [0952] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:04:24.944 [3652] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:04:37.439 [3652] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:04:37.689 [2036] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:04:38.696 [2964] Error — Unable to find title for item of type 5
Oct 09, 2019 19:04:38.698 [2964] Error — Unable to find title for item of type 5
Oct 09, 2019 19:04:55.971 [3344] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:04:56.096 [2036] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:04:57.212 [3612] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:04:57.259 [2036] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:04:58.625 [3528] Error — Error issuing curl_easy_perform(handle): 3
Oct 09, 2019 19:04:58.672 [0952] Error — Error issuing curl_easy_perform(handle): 3
