Server Version#: 1.13.5.5332 and previous 4 verions
Player Version#: 3.57.1
hopefully you can help me with this, it used to work perfectly but recently something seems to have changed.
this error happens if i connect directly by local ip, or using app.plex.tv.
the error code seems to be random, but usually picks one to start with, then more often stops at s3014, and happens exclusively with files that have AAC 5.1 audio encoded.
i believe that plex used to transcode AAC5.1 to AAC2.0 when using the web app, but it seems to have stopped doing this.
it doesnt seem to matter what browser i try and use, all of them do the same thing. server has been rebooted, and different client devices have also been tried and rebooted.
the plex chrome app doesnt seem to have any troubles, and the plex android app seems to work fine as well, as does plex media player (unfortunately this is not an option for at least one device since thanks to intel it only has a 32bit uefi - 32bit os only).
i have set the debug option under settings > web > debug to enabled, but am unsure which parts of the log to post here.
any help would be greatly appreciated.
EDIT: setting direct stream to off allows the files to play, but all of my media has been encoded in advance (using handbrake) to avoid transcoding video, which works fine most of the time (i use tautulli to monitor plex, and the video stream 99% of the time says “transcode - copy”, with direct stream off it is transcoding completely).
