Plex Web "Watch from these locations" error
Server Version#: 1.40.2.8395
Web Player Version#: 4.130.0
I have recently had a problem with the watchlist.
When I click on a movie, I normally see all available steaming services under “Watch from these locations”. But also my own media library.
However, my own media library is no longer displayed
I just checked this on my server and mine is doing the same thing. My server and web player versions are also the same as the original posters.
With this Beta Version the issue is solved
Plex Media Server 1.40.3.8502 is now available to Plex Pass users in the Beta update channel.
NEW:
  • (Auto Update) 32 bit installations of Plex Media Server running on 64 bit windows will be upgraded to 64 bit installations via auto update. (PM-1102)
  • (Web) Updated to 4.129.1
FIXES:
  • (Analysis) Analysis of items would be performed for chapter thumbs even if chapter thumb generation was disabled (PM-1212)
  • (Analysis) Slow DB queries caused analysis to be slow to start (PM-1211)
  • (GPU) Server would crash on startup if a user was running windows with Nvidia drivers installed but no Nvidia GPU. (PR-14862)
  • (History) Grandparent title and guid could get reversed
  • (Smart Collections) DB Optimize would make smart collections uneditable (PM-900)
the web version has been automatically upgraded to Web Player Version#: 4.130.0 The problem is back
when I install a new server version, everything works for a short time. But it takes less than 5 minutes and the error is there again.
A new test
When I log in to Plex again, everything works.
But as soon as I switch to a filography from e.g. Zendaya, my own library is no longer displayed…
I also noticed another problem in the course of this
Until recently, you could see which movie you had in a filmography. This was then marked with the name of the own media library.
But this is no longer the case.
Web Player Version#: 4.132.3
new status:
the error still occurs. but there is now at least a workaround:
If I now open a film from the watchlist and then refresh the page, I can see my own media library. After opening another movie/series you have to do exactly the same thing.
if you look at the filmography of an actor, you don’t get a visual indication of which film you have in your own media library. the same workaround works there too:
If you update the page there too, everything fits for the moment.
