Plex Web
1.0.3
Another minor update has been pushed with a few bug fixes and a new setting for allowing ac3 audio to be played directly.
NEW:
  • Shared users need to respect the 'Send anonymous usage data setting' when loading google analytics.
  • Added advanced player setting for allowing direct play of ac3 audio.
FIXES:
  • Fixed remote play not sending the correct context when playing some tracks.
  • Reset the poster in the music player if an album is played without artwork.
  • Don't show share / recommend if the user is not signed in to myPlex.
1.0.4
The biggest change you'll notice with this update is the new look for the default posters. There were a lot of "under-the-hood" changes though which should help us with updates moving forward.
NEW:
  •  Added new default posters.
  •  Updated layout of friends view.
  •  Updated channel list style and added settings button for channels that have their own settings.
  •  Replaced urls in translations with variables.
  •  Updated translations.
FIXES:
  •   Fixed some labels in the details views not being translated.
  •   Fixed issue that led to servers being incorrectly identified as remote.
  •   Fixed dropdowns in breadcrumb showing up behind the photo viewer.
  •   Prevent an invalid quality from being sent to the media server by resetting an invalid quality value to its default.
1.0.5
This is another update of small refinements. We've smoothed out some bumps in the setup wizard and improved the look of the myPlex section in the media server settings.
NEW:
  • Added support for splitting apart tv shows and music artists.
  • Improved consistency of spinners.
  • Updated myPlex settings in the setup wizard and server settings.
  • Unified the section list in the setup wizard with the dashboard.
FIXES:
  • Fixed invalid German translations.
  • Fixed bug when transcoding music after playing music from a different server.
  • Resolved differences between some translated strings and the strings used in the application.
1.1.0
Tired of using your mouse for everything? This update brings a lot of improvements to keyboard support, including loads of shortcuts and an early look at keyboard navigation. Take a look at the full list of shortcuts by pressing ? and you can always toggle off the keyboard shortcuts in the Plex/Web settings.
NEW:
  • Added keyboard shortcuts that can be toggled off in the Plex/Web settings.
  • Added early support for keyboard navigation using the arrow keys.
  • Improved tab focus support.
  • Added stop button to music player that fades out the song and closes the player.
  • If a channel does not have any directories or media, navigate back a level instead of showing a blank page.
  • Improved the music player slide animation.
FIXES:
  • Fixed invalid sync qualities when editing syncs started on Kepler.
  • Fixed sort by resolution not displaying the resolution in each list item.
  • Fixed issue preventing the setup wizard from advancing if the server fails to connect.
  • Don't require the user to sign in or sign up for myPlex in the setup wizard.
  • Fixed issue playing HLS channel videos that are mp4/h264/aac.
1.1.1
Alongside a lot various visual updates and bug fixes, this release brings a couple more filter shortcuts. You'll find Recently Released (movies) or Recently Aired (shows) and Recently Added is no longer limited to a fixed number.
NEW:
  • Added shortcuts for Recently Released (Movies) and Recently Aired (Episodes) to the sidebar. Remember which subset was last used and restore it when navigating to a section.
  • Reorganized the Activity view into distinct sections.
  • Improved keyboard navigation using the arrow keys.
  • Updated the look of the episode tile list.
  • Updated the season view to use the episode tile list.
FIXES:
  • Fixed video player dimensions when playing videos with an aspect ratio other than 16:9.
  • Fixed error when clicking photos in lists other than the tile list.
  • Fixed incorrect media being played occasionally when selecting an offset.
  • Fixed issue playing videos with the automatically select highest resolution setting.
  • Don't show the unwatched badge for albums.
1.1.2
This update has a workaround for a nasty little bug in Safari that was causing the action bar to disappear.
FIXES:
  • Fixed issue in Safari causing the action bar to appear invisible.
1.1.3
This update brings the ability to browse your episodes using your choice of list type as well as a couple fixes related to the new details views.
NEW:
  • Added ability to switch between list types in the season view.
FIXES:
  • Fixed thumbnails not loading in the details views.
  • Fixed music player overlapping the details views.
1.1.4
This update just contains a minor fix for multiuser (requires the 0.9.8.0 Plex Media Server). A much larger update is in the works though, so stay tuned.
FIXES:
  • Fixed watched status not showing up for some users.
1.2
Browsing large media collections has never been a great experience in Plex/Web. Performance would decrease the further you scrolled into the list and scrolling to the bottom of a large section was tedious. This release makes a few big steps in fixing that problem by introducing a new media list. The scrollbar now accurately reflects the full size of the list and you can scroll anywhere in the list immediately. This doesn't mean the startup time has increased, because we are still only requesting a single page of items initially. The alphanumeric list to the right now jumps around the list rather than filtering out items, letting you navigate your large collections more quickly. We've also made various other improvements and bug fixes, which you can find below.
NEW:
  • Increased performance when browsing sections by adding a virtualized media list.
  • Modified the media list to allow scrolling anywhere in the list immediately.
  • Modified the alphanumeric list to scroll to the correct position in the media list, rather than filter the list items.
  • Optimized image loading in the media list when scrolling away from list items before images have loaded.
  • Improved memory management with media items.
  • Added Recently Viewed filter.
  • Added fade effect to fanart.
  • Improved messaging when myPlex is down.
  • Updated Flash video player to latest version.
FIXES:
  • Fixed error when clicking on a photo in the global Recently Added list.
  • Fixed inconsistencies when identifying a server as remote or local.
  • Fixed some servers not becoming available after initialization.
  • Fixed sync items sending the container media type rather than the child media type.
  • Fixed the file availability check for videos with multiple files or when skipping the preplay view.
  • Fixed navigating sections served by Plex for Android.
1.2.1
As always with a major release, there were several bugs that were introduced, which should be addressed in this update. Multiuser features should be available again when accessing shared, remote servers. We've also added a new rating component that displays user ratings and allows you to modify the user rating directly.
NEW:
  • Added rating component that displays user ratings and allows for user input.
FIXES:
  • Fixed multiuser features not appearing when accessing remote, shared servers directly.
  • Fixed other inconsistencies when identifying a server as local or remote.
  • Don't require a successful local servers request even if a token is not required to hit the server.
  • Fixed disabled previous button for second episode in season.
  • Fixed section loading overlay interfering with list items when hidden.
  • Fixed unnecessary gap in media tile list.
  • Fixed overlapping titles in On Deck for shows.
You can now navigate through your metadata by clicking on tags (Genre, Director, Cast, etc.) in the pre-play views to quickly see other media items with that tag. We've also added several smaller changes and bug fixes in this release.
NEW:
  • Allow tags in preplay views to be navigated.
  • Added setting to displayed unwatched icon for movie lists.
  • Limit section subsets (Recently Added, Recently Released, etc.) to 200 items.
FIXES:
  • Fixed issues with searching within a subset.
  • Fixed broken album link in music player in a couple edge cases.
  • Fixed localization in now playing list item.
  • Fixed issue creating sync items from section subsets.
1.2.3
This update introduces several bug fixes and minor improvements to how sections are handled.
NEW:
  • Added support for the embed protocol when playing channel videos.
  • Improved section detection and added support for listing all sections in the breadcrumb dropdown.
  • Sections now maintain a sorted order on the dashboard.
  • Small layout improvements.
FIXES:
  • Update stream dropdown when media changes since subtitles may have been added or removed.
  • Fixed issue when pausing after a resume.
  • Fixed inconsistencies when identifying a server as local or remote.
  • Fixed issue with channel videos that have tags.
  • Fixed iPhoto photos not opening in the photo viewer.
  • Fixed a few issues with multiselect.
1.2.4
This update only contains a hotfix for a bug that was introduced by 1.2.3. In certain edge cases, the Plex Media Server settings would be empty.
NEW:
  • (none)
FIXES:
  • Fixed edge case that was causing the Plex Media Server settings to be empty.
1.2.5
This is another small update with a few bug fixes. Server connection testing should be a little more reliable and the broken myPlex links are fixed.
NEW:
  • Added error messages for sync errors.
FIXES:
  • Improved Blob constructor detection test.
  • Do not pass a server connection test if the server ids do not match. Fixes a rare edge case when the local address of a server resolves to a different server.
  • Fixed broken myPlex links.
1.2.6
Another small update with a few bug fixes has been released.
FIXES:
  • Fixed broken Refresh and Empty Trash buttons on dashboard.
  • Fixed playing videos on Kepler.
  • Fixed various issues with keyboard focus.
1.2.10
This release was primarily focused on "under the hood" changes for future development. You might notice that we've skipped a few versions as well. I'll be able to clear that up soon, but here are the release notes for now.
NEW:
  • Updated the Add Folder modal to better indicate top level directories and keep them available on the left for quicker navigation.
  • Added a new icon for users adding Plex/Web to the iOS home screen.
FIXES:
  • Fixed issue transcoding some channel videos.
  • Fixed icons displaying as Chinese characters on Opera for Windows.
  • Fixed wrong thumbs being used by photos when browsing through multiple albums.
  • Fixed server dropdown not updating view with new primary server.
  • Fixed fanart reappearing when navigating through a show or artist.
1.2.11
This update brings a lot of bug fixes, which should help tighten some loose screws that were reported in the forums.
NEW:
  •   (none)
FIXES:
  • Fixed dropdowns appearing behind content on iOS.
  • Fixed 4:3 images in now playing items not being sized correctly.
  • Lookup urls with the transcode server instead of going through node.
  • Use a square folder poster for music and photos when browsing by folder.
  • Use the universal transcoder for music when available. Fixes some flac tracks not automatically playing.
  • Fixed the icon in alerts showing up above the message.
  • Fixed the url in the share modal when an account is not linked.
1.2.12
Here's another small update with a few fixes for bugs that slipped through.
NEW:
  • (none)
FIXES:
  • Fixed z-index issue with dropdowns.
  • Fixed play button in now playing items leading to error.
  • Fixed stream dropdown and media info modal displaying Stereo instead of Mono for single channel audio.
1.2.15
This is a small update that fixes a couple of annoying bugs. It's been quiet here lately but rest assured that the silence means we are working hard on what's coming next.
NEW:
  • (none)
FIXES:
  • Added workaround for rendering bug in Chrome 30+.
  • Fixed sidebar in dashboard not closing in some cases.
1.2.16
Another minor update has been released, which fixes a regression caused by the workaround for the rendering bug in 1.2.15.
NEW:
  • (none)
FIXES:
  • Fixed regression caused by Chrome dashboard workaround.
