Plex Web
1.2.17
This is just a fix for another minor layout issue in Safari caused by the Chrome rendering bug workaround.
NEW:
  • (none)
FIXES:
  • Fixed an issue in Safari caused by Chrome dashboard workaround.
1.2.18
This update focuses primarily on the setup wizard. We've simplified myPlex integration and added an alert icon that lets you know when there was an error connecting your server to myPlex.
NEW:
  • Simplified connecting a server to myPlex in the setup wizard.
  • Added an alert icon in settings when there is an error connecting a server.
FIXES:
  • Fixed the app not starting up properly when local storage is disabled (Safari private browsing).
  • Fixed the section list header not updating when the section title changes.
  • Fixed the background not updating when the background changes.
1.2.20
We've made a few fixes related to Cloud Sync and syncing in general. Head over to the blog to read more about Cloud Sync.
NEW:
  • (none)
FIXES:
  • Fixed issues with Cloud Sync support.
  • Fixed syncing of photo albums.
1.2.21
We've fixed a small bug where servers could get stuck using a failed url, preventing their sections from being visible. The Chrome app has also been updated with this release, so you should see all the fixes from the last few versions in the Chrome app now.
NEW:
  • (none)
FIXES:
  • Fixed a case when servers would not use the correct url.
2.0.0
Happy Holidays! We've been working on a major upgrade to our web application over the last couple months and we're happy to finally release it to you. It can be accessed by going through our new website at https://plex.tv. Please note that the web application bundled with your media server will remain at 1.x until the 2.x build comes out of beta. We couldn't get all of the features from 1.x into 2.x for launch, but we will be working quickly to update 2.x over the next few weeks. Once 2.x comes out of beta, the bundled app and Chrome app will be automatically updated. One known issue that we are aware of is a limitation within Firefox. Some Firefox browsers seem to have issues with our ssl certificate and Firefox in general is stricter about mixed content requests, which means that remote servers won't be able to be accessed directly yet.
NEW:
  • Updated look and feel.
  • Improved dashboad layout.
  • Added server-less capabilities.
  • Faster, more flexibile browsing.
  • Added an experimental player setting, which allows DASH transcoding in supported browsers (this uses our new html video player instead of Flash).
  • Added Chromecast support (you must install the Google Cast browser extension to use this).
  • Added companion app capabilities.
  • Lots lots more, but it would take forever to list out every change here.
2.0.1
This is a minor bug fix follow-up to the 2.0.0 release. For more details about the 2.x web app, please read the 2.0.0 announcement.
NEW:
  (none)
FIXES:
  • Fixed error when connecting to certain remote players.
  • Fixed certain subsets not being limited to 200 items.
  • Fixed a bug when scanning sections.
  • Fixed a bug when filtering devices with a language other than English.
2.0.2
The Fix Incorrect Match modal has found its way back into the new 2.x app. We've also fixed a number of bugs and switched the page to be served over http. All communication with plex.tv still uses https, but communication with servers uses http. This fixes a number of issues related to https and DNS. If you were using Firefox and found that you couldn't connect to your server, please try again with this version. If you were using DD-WRT router software, you shouldn't be having DNS issues any longer.
NEW:
  • Added the Fix Incorrect Match modal.
  • Allow the hosted app to be served over http and redirect if authorization is needed.
FIXES:
  • Fixed a bug causing the trash icon to not show up for deleted items.
  • Fixed images not resetting properly when unmatching an item.
  • Fixed html entities in Chromecast player names.
  • Fixed password fields in channel settings displaying as regular text fields.
  • Fixed hiding the volume slider in the video player controls when the volume can't be controlled.
2.0.3
NEW:
  (none)
FIXES:
  • Fixed an error in the dashboard when the queue is empty.
2.0.4
NEW:
  (none)
FIXES:
  • Fixed a regression causing an infinite spinner in the server settings view.
2.0.5
NEW:
  (none)
FIXES:
  • Fixed a bug with Fix Incorrect Match and shows / artists.
2.0.6
On our march toward feature parity with the existing web app, we've added sync features back to the 2.x app. We've also fixed a few nasty bugs. As with any other 2.x update, you can find the latest at https://plex.tv/web.
NEW:
  • Added sync actions and sync activity.
  • Hide cursor if controls are hidden when using the html video player.
FIXES:
  • Fixed issue exposing management features with shared servers.
  • Limit experimental player option to browsers that support encrypted media extensions.
  • Refresh the sort options when changing the media type in a section.
2.0.7
Nothing major has been added in this update. We've fixed a few bugs and cleaned up a few areas of the app.
NEW:
  • Added sync button to track list item and photo player.
  • Show track duration in track list item.
  • Updated layout of queue and recommended list items.
  • Added delete action to action bar for queue and recommended items.
FIXES:
  • Fixed error when editing libraries.
  • Fixed error when canceling requests navigating to a view.
  • Fixed issue with video player controls constantly reappearing.
2.0.8
We've reintroduced the breadcrumbs and previous / next buttons in the details view. You can now even use a dropdown to navigate between seasons, episodes, or albums. We've also added support for a Duplicates filter, but this depends on something in Plex Media Server that hasn't been released yet, so you'll need to be patient and wait for the next media server release before that filter shows up.
NEW:
  • Added breadcrumb bar to details view.
  • Added rating and genres to album details view.
  • Allow deletion of specific quality when multiple qualities are available for an item.
  • Show advanced filters like "Duplicates" (requires Plex Media Server 0.9.9.1).
  • Use a separate button for "Update Library" in the library view.
FIXES:
  • Fixed navigating directly to a filter with a specific type.
  • Fixed sync items limited by duration.
  • Fixed the next action when controlling Plex players.
2.0.9
Artwork upload and selection is back in the 2.x app. It should work mostly as you've come to expect from the old app, with a few subtle differences. Sort context has also been added back into the app so you can see the criteria you are sorting by right in the list item.
NEW:
  • Added artwork upload and selection.
  • Show the context in each list item when using sorts.
FIXES:
  • Fixed the language not updating when changing a library's agent.
  • Fixed server language settings using text inputs instead of selects.
2.0.10
We are continuing to fill in some of the few remaining gaps in the new web app. In this update, the "Agents" section in server settings has been reimplemented. We've also added a couple minor fixes for issues that were reported in the forum.
NEW:
  • Added the agents section to the server settings page.
FIXES:
  • Fixed error when saving a metadata item without any changes.
  • Fixed saving boolean settings within channel and agent settings.
2.0.11
The Now Playing section within Activity has been reintroduced with a few upgrades. It now supports music and photos as well as videos. You'll also see the activity icon in the navigation bar is highlighted with the number of active now playing sessions.
NEW:
  • Reintroduced the "Now Playing" section.
  • Updated dropdowns to use a darker style.
FIXES:
  • Fixed inconsistency in section subset dropdown.
2.0.12
We've made various bug fixes for the companion app features (controlling other Plex players) and the Chromecast player. Changes specific to the Chromecast player, the app that actually runs on your Chromecast device, are noted below.
NEW:
  • Increased pause timeout to 20 minutes (Chromecast).
FIXES:
  • Fixed playing YouTube videos within the app.
  • Fixed remote playing Queue and Recommended videos on Plex players.
  • Fixed decision to transcode Cloud Sync videos or videos from servers that cannot transcode if it's not necessary.
  • Fixed Direct Stream setting not working correctly (Chromecast).
  • Fixed transcode sessions not being stopped correctly (Chromecast).
  • Fixed progress not being saved correctly in some cases (Chromecast).
  • Allow subtitle size and audio boost settings to be specified by senders (Chromecast).
2.0.13
A setting now allows you to show unwatched icons in list items. Episode list items when browsing a season will display unwatched icons whether this setting is enabled or not.
NEW:
  • Added watched icons to list items, which can be enabled with a setting.
  • Tweaked the selected style of posters when changing artwork.
FIXES:
  • Fixed the default user poster in the now playing list.
2.0.14
This is a minor update that fixes the browse button after installing a channel. We've also updated the Flash video player used in the app.
NEW:
  • Updated the Flash video player to the latest version.
  • Added a link to the thumb in announcements.
FIXES:
  • Fixed the browse button in the channel modal after installing a channel.
2.0.15
This is another minor update that fixes an issue with RTMP channels (which are still disabled for the v2 app, but that will change shortly).
NEW:
  • (none)
FIXES:
  • Fixed setting up the Flash video player for RTMP channels.
