i’m sorry, not that i know of
Is it a PMS update or an android app update?
Neither, the cast receiver in the cloud.
OK, got it. Wasn’t sure which part of the process had the issues. I’ll try it now and report back. ![]()
Still having issues in Australia, original chromecast it tries to load with a small spinning wheel which eventually times out before return to the chromecast screensaver
Firing on all cylinders here!
Many thanks! ![]()
Still broken for me in Canada. Hasn’t worked for a few days… I think since the last app update.
Still broken in italy
@slayer3210 The new experience also can’t cast unless you connect to a device first and the hit play. Shuffling breaks it. I’ve already made another thread. They need to stop trying to “fix” things that aren’t broken and actually fix the things that are.
Just recieved the new app interface today but casting from Plex results in the screen turning green. I can hear the audio, but the image is useless. Casting from other apps works without issue.
I have this issue since the new layout came out (Android), but so far I have managed it by disabling auto update on the Plex app and rolled back with re-install when was needed.. but I got a “new spare phone” last weekend, and forgot to disable auto update, and last night it did update to 2025.14 version and since I can’t reinstall just the same version, and have the same “No Devices Found”.. I believe it doesn’t even look for a device as it is way too quick to pop up.. I have couple Chromecast Gen 2, and all works from other apps like youtube or netflix or Disney+ or Google TV…
I tried on multiple Wifi link over, and I can always ping the chromecast and see it online on Google Home.. but Plex just doesn’t like.. at the same time my misses Plex that hasn’t been updated still works just fine…
Any solutions?
I had the sane problem, risolved here Plex Android App don't find cast devices
Enabling config.claspws.tv on my pihole
That is interesting.. indeed I have pihole on my network.. I will try this asap when I get home.. Thank you!
I’m having the same problem, but I don’t have pihole in my network, I’m using adguard, that doesn’t seems to have similar configs.
At the moment, to be able to cast I need to open Plex via web with Chrome, luckily I have an ssl certificate on my server
Oh, sorry, it was a domain to whitelist, Ok, that fixed the problem for me too
I like how we can blame Google for it, but old versions of the app work perfectly fine
Which only proves it’s Plex changing protocols for ABSOLUTELY 0 REASON. I can’t believe that a company would destroy their own software at nearly every aspect for 0 reason like this. Functionality, design, UX, everything. And for what? So a few creative directors and devs can justify that they still need to have jobs?
Same here! I have Chromecast and ever since I got the new (Android) app update I have been unable to connect to my Chromecast.
It just sits and spins then after a while the connecting window goes away and it stops trying to connect. No error. All the other apps on my phone work as expected when casting
Samsung Galaxy s24 ultra
one UI 7
