Plex will not play any hi-res flac files
Hi! I am having a huge problem with my plex server running from a Synology NAS. None of my hi-res music files in flac format (24/192) will play.
This happens in the PC browser (error: Playback error, check that the file and the necessary drive is mounted). However, normal flac files play totally normal. I am really at a loss.
I also checked, the playback is also not working on my ios and other devices,. whereas normal flac play without issues.
Many thanks for ideas …!
Hi Trumpy81, many thanks for your support. I checked Q18, but had some issues with the process resulting from it inside the terminal. However, I then decided to create a new shared folder on my NAS (permission allowing ALL), and then created a new library on PLEX. That fixed the issue and I am now listening to the Flac files. Thanks for taking the time to reply.
