Plexamp 3.2.0 bug: last Google Cast entry not selectable when scrollbar is present
In Plexamp 3.2.0, I’m unable to select the last device entry in the list to Cast once the scrollbar appears.
I tried restarting the app a few times and rebooting my phone (Pixel 4XL). Refreshing the Cast device list also didn’t help, and in some cases the order would change or some devices wouldn’t be available right away, so it was not a device-specific issue. No matter what, once the scrollbar appeared, I couldn’t select the last item in the Cast device selection list.
Known issue, fixed in the next release.
I don’t think you can play to “airplay” either. This would be a great feature to Plexamp.
Great. Thanks, @elan.
AirPlay is not supported on Android.
I was talking about Iphone.
New release isn’t out on iPhone but we’ve always supported AirPlay using the system menu, pull down from top right. In v3.2 we’ve made it easier with a dedicated button (bottom right).
Screen Shot 2020-09-13 at 5.13.40 PM
on this note, i could have sworn there was a checkbox option in the Android Plex app before that turned on Airplay Discovery in the settings menu that would then show airplay supported devices in the casting list. am i crazy? i actually needed to beam something to an AppleTv at a friend’s house today using my android phone and had no luck.
it’s quite possible we had support in the past for that (maybe even present??), i can’t completely recall :wine_glass:
