Plexamp airplay to ATV4k - no bass
No idea, the plex client works fine, but anytime i try to use plexamp to my apple tv, be it my iPhone or iPad, there’s no bass, like none. I made sure all the EQ stuff was turned off, still no bass.
I’m clueless at this point.
Sounds like an issue between Apple TV and receiver, nothing Plexamp is doing.
are you using a sub and some kind of AV receiver?
in which case airplay might just route to the front 2 channels?
Plex on Apple TV works fine, bluetooth and plexamp from iPad/iPhone to Apple TV works fine. It’s only plexamp + airplay.
There is no configuration or control Plexamp has over what is sent via AirPlay.
