I started organizing my music library (daunting task to do) using the musicbrainz picard app and see that they sort album artist by last name first which is extremely annoying considering everyone else does first name. Will plex allow to display first name organization? or is this something i need to edit myself.
Plexamp does sort “Album Artist” by whatever is actually in the Album Artist tag in your track file (e.g. flac file). So for example, my Album Artist tag value is “Bruce Springsteen”, not “Springsteen Bruce”. But I use dbPowerAmp to create my flac files and that program’s default option is to generate as (first name, last name) with an option to perform (last name, first name). As stated, most music software went with (first name last name) as the default. This of course is the exact opposite of what physical media record stores have been doing since the dawn of time ![]()
Hi @Tenrai-Sensei I had a similar question, refer to the below for options:
You can override musicbrainz Picard with scripting
I used this script from the musicbrainz forum…
This sets albumartistsort for names like “Bruce Springsteen” but will ignore artists with “the” at the beginning so keeps those like “Beatles, the”
Thank you for all the reply everyone xD Jimbob i just add this works like a charm much appreciated!!!
Isn’t that the default behaviour of Plex anyway?
The only difference is that “The Beatles” turn into just “Beatles” for the Sorting Title.
(provided you don’t have the ugly ArtistSort and AlbumSort metatags in your files. MB Picard can be taught to not write these.)
This was exactly why the original post exists and that is why I offered the script
FYI… album sort can also suffer from this sorting depending on your tags. This is what I do within picard to control the sorting so I get the sorting in plex exactly how I want it …
$set(artistsort,%albumartist%)
$set(albumartistsort,%albumartist%)
$set(albumsort,%album%)
