Trying to setup Plexamp and PlexDash (I am a PlexPass lifetime sub), but both of these apps don’t find my server. I’m on my LAN but also have remote access enabled and that works too.
Any tips/advice are appreciated.
With the plex user account that you are using to post in this here forum, you are not.
There is also no server in this user account.
So I’m assuming that you are using more than one plex accounts. Verify that you are using the same user account in all your clients, under which your server has been claimed as well.
Well that solved it! Google had an old username/password saved that wasn’t my actually account I actively use… Simple problem with an easy solution, thanks!
