Plexamp autoplay setting ignored on headless client
Using the Android app as my “controller” where autoplay is turned off, when I fling music to a headless client, this setting is ignored and autoplay kicks in when the current album finishes.
If I play just on my phone, the autoplay works correctly with playback stopping when the album is complete.
Just wondering if anyone else is experiencing this behaviour before I start digging into logs.
Thanks.
I believe you need to turn off autoplay on the headless device itself by logging into x.x.x.x:32500 to access the device UI.
Thanks, Elan. I forgot I could get to all the Plexamp settings via an HTTP to that port. I now have autoplay disabled on the headless install.
I’m actually cheating a bit as I’m using the Plexamp client built into RoPieee but it works a treat and is almost zero effort to get set up.
