Plexamp blanks out on play
I’m running pleaxamp on Centos 8 and Fedora 32 and when I start it up, I can login and see my library. But once I click play, the screen blanks out.
Here is the output from the command line:
Started Media Service: false
Linux: Registering MPRIS service.
(node:32520) Electron: Loading non context-aware native modules in the renderer process is deprecated and will stop working at some point in the future, please see https://github.com/electron/electron/issues/18397 for more information
Checking for update
(node:32520) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
Update for version 3.2.1 is not available (latest version: 3.2.1, downgrade is disallowed).
checkForUpdatesAndNotify called, downloadPromise is null
blank screen implies a player crash.
OK, Is there any thing that I can report that can get this fixed?
I used an older version 1.x forever and it worked, then I upgraded, and now it fails.
If I could grab an older version and use that I would.
Probably https://plexamp.plex.tv/plexamp.plex.tv/plexamp-1.1.0-x86_64.AppImage
People are running it successfully on some distributions, but it’s hard to keep track of everyone across all of them so you might want to have a look around these forums and see if people have reported a similar issue :sweat_smile:
