I’ve been having issues with Plexamp since updating the local client to 4.7.x
When using my device remotely, tracks are buffering every few seconds. Test track (Beck Heart Is A Drum). There are no issues playing on internal network.
Prior to 4.7.x the same files have played perfectly when streaming.
Cell signal has good signal strength, other serves reliant on an internet connection works fine… Even normal Plex (I.e. Video content). Plex server has the lovely green tick to the outside world, eliminating from my perspective any home network firewall issues.
ISP connection has no issues (no throttling, not a line fault etc).
I’ve attached the log file, but I’m not 100% certain how to interpret what it’s telling me.
I went through the logs, and there is buffering. However, nothing changed in 4.7.x with respect to buffering that I’m aware of and the logs look normal for a situation with poor network bandwidth.
It’s possible your ISP changed some throttling rules. Run your server at port 443 or 8443 to try to avoid this, as they are more prone to punishing other ports.
Hmm, I think it’s potentially a server issue, I’ve raised it internally. Do you have any bandwidth limit set? It seems to affect transcoded streams so you can test with quality up and see if that makes a difference.
If you figure out it was a server issue, please let us know which version you’re seeing the problem in and which one you’re not.
You must uninstall the current version, then install the older version.
When uninstalling, use the first, Uninstall Only option.
After installing the older version, you may initially see a 503 Maintenance message when connecting to PMS via Plex Web. That is expected. Plex is adjusting the database schema. Wait a few minutes and try again.
I guess I’m going to stay at Plex Server level 6918 until I get confirmation that a new server level won’t adversely affect my Plexamp remote streaming. I use Plexamp in my car every day.
Same here, not just on mobile/cell but when I’m transcoding on remote wifi as well. If I turn off remote access and use Tailscale to connect it transcodes fine on all networks. 1Gbps ISP connection at the server, at least 50Mbps everywhere else. Lossless streams just fine as well, so it seems to be a transcoding/networking problem.
Using PMS 1.32.3.7089, plexamp 4.7.4 on iphone and linux
Happy to provide logs if someone tells me what to do!
That’s interesting, thanks. Still having the same problems though - extremely slow buffering while using remote access. Which server version fixed it? As far as I’m aware, I’m on the latest beta.
Still trying to figure out if it’s a problem with my setup or not
