plexamp Console Logs
Nov 13, 2020 15:44:24.332 [Javascript] INFO - METRICS: Initializing.
Nov 13, 2020 15:44:24.333 [Javascript] INFO - USER: Refreshing users.
Nov 13, 2020 15:44:24.336 [Javascript] INFO - DEVICE: Loaded 3 devices.
Nov 13, 2020 15:44:24.337 [Javascript] INFO - DEVICE: Initializing manager.
Nov 13, 2020 15:44:24.337 [Javascript] INFO - DEVICE: Fetching latest provider list from cloud.
Nov 13, 2020 15:44:24.337 [Javascript] INFO - DEVICE: Fetching latest list from cloud.
Nov 13, 2020 15:44:24.337 [Javascript] INFO - DEVICE: Fetching latest cloud player list from [https://sonos.plex.tv](https://sonos.plex.tv/)
Nov 13, 2020 15:44:24.338 [Javascript] INFO - DEVICE: Starting connection test.
Nov 13, 2020 15:44:24.365 [Javascript] INFO - DEVICE: Fast-path connection testing.
Nov 13, 2020 15:44:24.366 [Javascript] INFO - DEVICE: Finding best connection for Podcasts tv.plex.provider.podcasts.
Nov 13, 2020 15:44:24.366 [Javascript] INFO - DEVICE: Skipping actual connection testing for Podcasts.
Nov 13, 2020 15:44:24.366 [Javascript] INFO - DEVICE: Finding best connection for [system name removed] 016842F3-8968-49C4-93FD-99D0187C75FE.
Nov 13, 2020 15:44:24.367 [Javascript] INFO - HTTP: Issuing request to http://[internal ip address of Apple TV]:32500/resources
Nov 13, 2020 15:44:24.367 [Javascript] INFO - DEVICE: Persisting devices.
Nov 13, 2020 15:44:24.367 [Javascript] INFO - DEVICE: Initialization finished in 30ms.
Nov 13, 2020 15:44:24.370 [Javascript] INFO - App: Device manager initialized in 37ms.
Nov 13, 2020 15:44:24.372 [Javascript] INFO - DEVICE: Reading libraries and features from Podcasts
Nov 13, 2020 15:44:24.372 [Javascript] INFO - HTTP: Issuing request to https://podcasts.provider.plex.tv/
Nov 13, 2020 15:44:24.373 [Javascript] INFO - Sync: Loaded in 3ms.
Nov 13, 2020 15:44:24.373 [Javascript] INFO - Sync: Refreshing all items.
Nov 13, 2020 15:44:24.373 [Javascript] INFO - ACCOUNT: Refreshing data.
Nov 13, 2020 15:44:24.386 [Javascript] INFO - LRUCache: Loading 123 entries into Palette cache.
Nov 13, 2020 15:44:24.387 [Javascript] INFO - LRUCache: Loading 317 entries into Loudness cache.
Nov 13, 2020 15:44:24.390 [Javascript] INFO - LRUCache: Loading 1312 entries into Images cache.
Nov 13, 2020 15:44:24.390 [Javascript] INFO - App: Settings, offline and cache initialized in 20ms.
Nov 13, 2020 15:44:24.390 [Javascript] INFO - Audio: Initializing.
Nov 13, 2020 15:44:24.390 [Javascript] INFO - Audio: Binding settings.
Nov 13, 2020 15:44:24.391 [Javascript] INFO - Audio: Setting player info.
Nov 13, 2020 15:44:24.391 [0x00b89e00] DEBUG - BASS: Starting up.
Nov 13, 2020 15:44:24.398 [0x00b89e00] INFO - BASS: Device 1: Default - enabled default - sample rates:
Nov 13, 2020 15:44:24.399 [0x00b89e00] INFO - BASS: Device 2: Built-in Output - enabled default handset hdmi headset line speakers - sample rates: 44100/48000/96000
Nov 13, 2020 15:44:24.399 [0x00b89e00] INFO - BASS: Device 3: USB AUDIO CODEC - enabled handset hdmi headset line speakers - sample rates: 32000/44100/48000
Nov 13, 2020 15:44:24.400 [0x00b89e00] DEBUG - BASS: Using plugin path '/Applications/Plexamp.app/Contents/Resources/treble/'.
Nov 13, 2020 15:44:24.406 [0x00b89e00] INFO - BASS: Loaded FLAC plug-in version 2.4.4.3
Nov 13, 2020 15:44:24.414 [0x00b89e00] INFO - BASS: Loaded OPUS plug-in version 2.4.1.13
Nov 13, 2020 15:44:24.421 [0x00b89e00] INFO - BASS: Loaded APE plug-in version 2.4.2.0
Nov 13, 2020 15:44:24.427 [0x00b89e00] INFO - BASS: Loaded MPC plug-in version 2.4.1.2
Nov 13, 2020 15:44:24.434 [0x00b89e00] INFO - BASS: Loaded DSD plug-in version 2.4.1.2
Nov 13, 2020 15:44:24.434 [0x00b89e00] INFO - BASS: Core version 2.4.15.13
Nov 13, 2020 15:44:24.434 [0x00b89e00] INFO - BASS: Mixer version 2.4.9.18
Nov 13, 2020 15:44:24.434 [0x00b89e00] INFO - BASS: FX version 2.4.12.3
Nov 13, 2020 15:44:24.434 [0x00b89e00] INFO - BASS: Curl version is 7.65.1 (protocols: dict file http https; ssl: SecureTransport; libz: 1.2.11).
Nov 13, 2020 15:44:24.435 [0x00b89e00] ERROR - BASS: Error [BASS_FXSetParameters(m_volume, &m_volumeParam)] - 5
Nov 13, 2020 15:44:24.436 [Javascript] INFO - PlayQueue: Saving state {"state":"stopped","volume":100}
Nov 13, 2020 15:44:24.436 [Javascript] INFO - PlayQueue: Initializing volume to 100.
Nov 13, 2020 15:44:24.436 [Javascript] INFO - App: Player initialized in 46ms.
Nov 13, 2020 15:44:24.437 [Javascript] INFO - Server Activity: Connecting based on switch.
Nov 13, 2020 15:44:24.438 [Javascript] INFO - Server Activity: Trying to connect to 5ec48547d5bf7a05a7b1e28d9db1faab95e5738f.
Nov 13, 2020 15:44:24.445 [Javascript] INFO - Player: Initializing with state {"state":"stopped","volume":100}
Nov 13, 2020 15:44:24.445 [Javascript] INFO - Discovery: Refresh based on server/library switch.
Nov 13, 2020 15:44:24.445 [Javascript] INFO - Discovery: Fetching hubs for library /library/sections/14 server 5ec48547d5bf7a05a7b1e28d9db1faab95e5738f
Nov 13, 2020 15:44:24.446 [Javascript] INFO - App: Stopping activity recognition.
Nov 13, 2020 15:44:24.446 [Javascript] INFO - Player: Sending state changed [A] - (0/0) in state stopped with artwork false.
Nov 13, 2020 15:44:24.447 [Javascript] INFO - Network changed: type is unknown effectiveType is 4g -> 2
Nov 13, 2020 15:44:24.447 [Javascript] INFO - Discovery: Refresh based on network coming online.
Nov 13, 2020 15:44:24.447 [Javascript] INFO - Discovery: Fetching hubs for library /library/sections/14 server 5ec48547d5bf7a05a7b1e28d9db1faab95e5738f
Nov 13, 2020 15:44:24.447 [Javascript] INFO - Sync: New network type 2
Nov 13, 2020 15:44:24.447 [0x00b89e00] INFO - BASS: Network switched to 2.
Nov 13, 2020 15:44:24.447 [Javascript] INFO - App: Network is connected, but type changed to 2, so doing preemptive connection testing on selected server.
Nov 13, 2020 15:44:24.447 [Javascript] INFO - DEVICE: Finding best connection for Uranus 5ec48547d5bf7a05a7b1e28d9db1faab95e5738f.
Nov 13, 2020 15:44:24.447 [Javascript] INFO - HTTP: Issuing request to https://[removed private ip address].5f7c471db47d4a16825bff738c0982c2.plex.direct:32400/
Nov 13, 2020 15:44:24.447 [Javascript] INFO - HTTP: Issuing request to https://[removed public ip address].5f7c471db47d4a16825bff738c0982c2.plex.direct:32400/
Nov 13, 2020 15:44:24.455 [Javascript] INFO - HTTP: Issuing request to https://[removed private ip address].5f7c471db47d4a16825bff738c0982c2.plex.direct:32400/hubs/sections/14?count=4&includeExternalMetadata=1&excludeElements=Similar,Mood&includeLibraryPlaylists=1&includeStations=1&includeStationDirectories=1&excludeFields=summary&includeFields=thumbBlurHash&X-Plex-Device-Name=neptune
Nov 13, 2020 15:44:24.455 [Javascript] INFO - HTTP: Issuing request to https://[removed private ip address].5f7c471db47d4a16825bff738c0982c2.plex.direct:32400/library/sections/14/all?type=10&sort=lastViewedAt:desc&group=guid&viewCount>=1&limit=4&includeFields=thumbBlurHash&X-Plex-Device-Name=neptune
Nov 13, 2020 15:44:24.456 [Javascript] INFO - HTTP: Issuing request to https://[removed private ip address].5f7c471db47d4a16825bff738c0982c2.plex.direct:32400/hubs/sections/14?count=4&includeExternalMetadata=1&excludeElements=Similar,Mood&includeLibraryPlaylists=1&includeStations=1&includeStationDirectories=1&excludeFields=summary&includeFields=thumbBlurHash&X-Plex-Device-Name=neptune
Nov 13, 2020 15:44:24.456 [Javascript] INFO - HTTP: Issuing request to https://[removed private ip address].5f7c471db47d4a16825bff738c0982c2.plex.direct:32400/library/sections/14/all?type=10&sort=lastViewedAt:desc&group=guid&viewCount>=1&limit=4&includeFields=thumbBlurHash&X-Plex-Device-Name=neptune
Nov 13, 2020 15:44:24.464 [Javascript] INFO - Cloud: Loading from storage 20 items and 1 deleted.
Nov 13, 2020 15:44:24.464 [Javascript] INFO - Cloud: Syncing.
Nov 13, 2020 15:44:24.465 [Javascript] INFO - App: Stores initialized in 29ms.
Nov 13, 2020 15:44:24.465 [Javascript] INFO - Shortcuts: Initializing!
Nov 13, 2020 15:44:24.466 [Javascript] INFO - Init: Stores all initialized.
Nov 13, 2020 15:44:24.467 [Javascript] INFO - App: Boot complete in 153ms.
Nov 13, 2020 15:44:24.480 [Javascript] WARNING - Animated: `useNativeDriver` is not supported because the native animated module is missing. Falling back to JS-based animation. To resolve this, add `RCTAnimation` module to this app, or remove `useNativeDriver`. More info: https://github.com/facebook/react-native/issues/11094#issuecomment-263240420
Nov 13, 2020 15:44:24.548 [Javascript] WARNING - PanGestureHandler is not yet supported on web.
Nov 13, 2020 15:44:24.549 [Javascript] WARNING - PanGestureHandler is not yet supported on web.
Nov 13, 2020 15:44:24.797 [Javascript] INFO - HTTP: Issuing request to https://[removed private ip address].5f7c471db47d4a16825bff738c0982c2.plex.direct:32400/library/metadata/152839/children?includeFields=thumbBlurHash&X-Plex-Device-Name=neptune
Nov 13, 2020 15:44:24.798 [Javascript] INFO - HTTP: Issuing request to https://[removed private ip address].5f7c471db47d4a16825bff738c0982c2.plex.direct:32400/library/metadata/152827/children?includeFields=thumbBlurHash&X-Plex-Device-Name=neptune
Nov 13, 2020 15:44:24.798 [Javascript] INFO - HTTP: Issuing request to https://[removed private ip address].5f7c471db47d4a16825bff738c0982c2.plex.direct:32400/library/metadata/152808/children?includeFields=thumbBlurHash&X-Plex-Device-Name=neptune
Nov 13, 2020 15:44:24.798 [Javascript] INFO - HTTP: Issuing request to https://[removed private ip address].5f7c471db47d4a16825bff738c0982c2.plex.direct:32400/library/metadata/152768/children?includeFields=thumbBlurHash&X-Plex-Device-Name=neptune
Nov 13, 2020 15:44:24.800 [Javascript] INFO - HTTP: Issuing request to https://[removed private ip address].5f7c471db47d4a16825bff738c0982c2.plex.direct:32400/library/metadata/131478/children?includeFields=thumbBlurHash&X-Plex-Device-Name=neptune
Nov 13, 2020 15:44:24.800 [Javascript] INFO - HTTP: Issuing request to https://[removed private ip address].5f7c471db47d4a16825bff738c0982c2.plex.direct:32400/library/metadata/148196/children?includeFields=thumbBlurHash&X-Plex-Device-Name=neptune
Nov 13, 2020 15:44:24.801 [Javascript] INFO - HTTP: Issuing request to https://[removed private ip address].5f7c471db47d4a16825bff738c0982c2.plex.direct:32400/library/metadata/152739/children?includeFields=thumbBlurHash&X-Plex-Device-Name=neptune
Nov 13, 2020 15:44:24.801 [Javascript] INFO - HTTP: Issuing request to https://[removed private ip address].5f7c471db47d4a16825bff738c0982c2.plex.direct:32400/library/metadata/148386/children?includeFields=thumbBlurHash&X-Plex-Device-Name=neptune
