Plexamp continuously spinning on macOS
Good morning! I loaded up my Plexamp (latest mac release) this morning on my Mac (M2, 15.1), and suddenly the macOS app does not want to show anything besides a loading screen.
If I close the application and relaunch it, it will quickly show my library, load up what I assume is the Now Playing window, but just hang there with no navigation or anything.
It’s very strange; all other Plexamp clients are working fine. I can play music through the Plex app with no problem.
I’ve tried restarting the Plex server (running in Docker) as well as uninstalling the Plexamp app from my Mac and redownloading. Is there a config somewhere I should be deleting?
Any idea what could be causing this issue?
Thanks for your support and long live Plexamp!!
Plexamp.log (49.2 KB)
Would probably help if I uploaded some logs.
Narrator: It did.
It looks like for some reason your play queue was nuked. Can you just hit ESC to get out of the player screen and play something else?
ESC worked. I feel so silly. Thank you Elan!
