This maybe a linux desktop specific issues, but I would like to request another couple of larger scaling options for text/grid size. On a 3k/4k+ display, even with both options set the the largest size, the interface is quite small.
I used to pass --force-device-scale-factor=1.5 to get a decent size. Using GDK_SCALE, etc… doesn’t seem to work.
Try changing settings → experience → font size to Mega and see if it helps.
Also, you might want to adjust the view to use grid or carousel as that looks better on a large display. Just select the three dots on the right (under the play button) and scroll down to change from list.
that is on Mega ![]()
Really, it doesn’t look that small on my 1440p display ![]()
my handheld is 1600p, which looks mostly fine. I would prefer 1 step larger, but its workable.
Its just the nature of using fixed font sizing. 4k is 50% smaller relative to 1440p.
