Plexamp Feedback iOS
Server Version#:1.19.2.2711
Player Version#:3.0.1
Having played around with Plexamp on iphone for a little while now I wanted to provide some feedback.
I’ll start by saying that for a while now I’ve had an issue playing long audio files with the iOS Plex player. I frequently run into the player freezing up when trying to change tracks, as well as some audio noise that doesn’t appear when played on natively on my PC. Thats kind of a background to my Plexamp comments.
Anyway so my first comment is that unlike my audio issues with the main iOS Plex client, when playing those same files with Plexamp I see none of those issues. No issues with audio noise or the app freezing when changing tracks. This I’ll admit confuses me given I would have figured both would use the same underlying audio playback code.
I guess my other comments relate to my server library setup. Firstly I have multiple audio libraries and I do find it annoying that I have to manually change libraries to access audio, unlike the main plex client. Secondly with me playing very long audio tracks I really do with the player had controls to jump forwards or backwards within a track. its pretty awkward to try and just drag along the timeline to move forward or backward. I wish there was skip ahead/back 30 seconds or a minute or something. Lastly (and I guess this also applies to the normal plex client) I wish searches returned collections.
Both do use the exact same player library, but slightly different versions (Plexamp is more on the bleeding edge).
Noted.
Also noted.
I only recently started using Plex for music (have used it for years for TV/Movies) and I guess it was well timed! Overall PlexAmp really whips The Llama’s ass! (on both Linux/iOS where I use it). I agree with swapping libraries being a little cumbersome, but I feel this for native web UI as well when trying to use three music libraries, in addition to Tidal.
For the iPhone app I would love to have better integration between libraries, or at least the ability to switch libraries as a more forward option instead of having to go to settings and then select a library.
The other thing… Oh how I would love CarPlay support!
I’ve just discovered Plexamp for iOS after being a long time user of the desktop version. I really like the route it’s going, many thanks for this cool release!
The only thing annoying me as well is switching libraries. As I have a lot of music I organise it in around 12 libraries. How about a small improvement in the UI which would be similar like in the Plex App: Swiping left on the home-screen could take me to the library list.
May I add a feedback / feature request? (sorry, I’m new to the forums and can’t find the new topic button)
Could we have a shuffle/random play all for the entire music collection please? :metal:
Thank you :notes:
Plexamp iOS v3.0.3
I suppose that’s what the library radio is doing… isn’t it? :wink:
Hmmm… that’s not my understanding:thinking: :upside_down_face:
In Plex Web, go to your music library (on the ‘Library’ tab).
Without selecting any artist/album first, click on ‘Add to Playlist’.
Name the Playlist ‘All Music’ or something like that
play this playlist in Plexamp.
See how that goes for you.
If you have a particularly big collection, you might want to adjust the hidden server preference RadioDaysSinceLastPlayed to a higher number of days.
@OttoKerner - thank you for the workaround as I assume I’d need keep this ‘All Music’ playlist up to date manually.
I’d still like the ability to shuffle the entire music collection in the iOS Plexamp please! :notes:
No, this is a ‘smart’ playlist. It keeps itself up to date. All playlists which were made from “filters” (without selecting any item manually!) are doing this.
You can tell by the little ‘cog wheel’ icon on top of the poster, when you look at the playlist in Plex Web
smart_playlist
Thanks @OttoKerner - I followed your instructions and this ‘All Music’ magic playlist appears to do what I’m after! It’s also at the top of the ‘Recent Playlists’ in Plexamp for iOS so it’s easy to find too.
Thanks again :+1:
@OttoKerner - Quick follow-up questions if I may…
Why would I need to adjust this preference?
Also - after a few days of using the ‘All Music’ playlist, I’ve a sneaking suspicion that it is favouring the ‘popular tracks’ in the smart playlist over the the other non-popular tracks - would you know if this is the case?
Because it is set by default to just 2 days.
Which means, if you have a lot more music in the radio or playlist than you can play in 2 days, the less popular track will never get played.
Increasing this value will cause the more popular/(or higher ‘rated’) tracks to stay longer in ‘demoted’ state, so they are not bubbling up to the top again, if they have been played already = more diversity.
Thanks for replying so quickly @OttoKerner, I’ve updated the RadioDaysSinceLastPlayed setting so I should hear more variation from my music collection
+1 to OP’s wish to have “skip ahead/back 30 seconds” buttons :smiley:
Loving Plexamp, I’m really enjoying my music again now. No more iTunes!
Hey now - would love to be able to jump to a letter when scrolling through all music - similar to the regular Plex App. Any plans to put this in?
Indeed.
thank you so much for letting me know! once this is in it will make browsing through my music so much easier.
my fingers are also crossed for alexa support - it would be awesome to be able to choose which music to play on my phone and cast to Alexa speakers.
Having 30-second skip backward/forward is dumb tbh. No other music app has it for a reason. It would clutter up the Now Playing screeen and the usage would be minimal as people skip/replay whole songs.
the 30 second seek, could be useful those who use plexamp for podcasts/audiobooks, so its not that unusual of a request.
that said, you can seek by sliding the audioprint just above the song title info
