Plexamp: Manually change volume / volume profiles
The idea of bundling the volume to system volume is great but doesn’t work anymore when there are two or more programs running that are battling for audio and it’s volume. I like to have teamspeak open, talking to friends and like to listen to music in the background. Well, plexamp disqualifies itself by not letting me change volume to match it with other software.
If plexamp is running on its own, it works great the way it is.
I would like to have a way (and even if it is hacking a config json file) to give myself the option to change the volume for situations I described. Thanks.
An idea are volume profiles:
  • I can set my own profile (in a config json would be fine), give it a name and volume and can choose from the system menu
  • It ships with one profile (volume = system volume)
  • If there are more profiles, then a menu is shown in the system menu
So I can create a profile for background music with a volume level set to hmm 55% and can choose in the system menu, that would be neat.
Upvote.
We’re thinking about just allowing “soft” volume control so you can adjust the volume of Plexamp independently of system output. Purists can keep it at 100% and others can tweak the volume (at first likely via key-binding).
You can use mpc to independently change the volume of Plexamp - mpc - Music Player Daemon
The current mpd port Plexamp runs on is 36600
$ mpc -p 36600 volume 60
I’m sure there’s an mpc like client that talks to mpd that runs on Window but I’ve not looked. If push came to shove you could install an iOS/Android mpc client on your phone to change the volume on the host machine.
Edit: Typo’d the port.
Doesn’t MacOS have something like this?
Only buggy third party software, some open source, some of it commercial. Frequently, said software will suddenly stop working and require the client software to be restarted for audio output to continue.
Suggestions on macOS discussion channels and forums leads people to helpfully remind me that “everything already has its own built-in volume control, so we don’t need a system-wide volume mixer”.
In the next release we’ll have a keyboard command to raise/lower Plexamp (soft) volume.
any word on this? I’m digging the minimalism a lot and not needing a browser open. Just need it to not compete with other applications I’m running.
EDIT: Found my own answer: we need volume control (pelxamp)
OPTION+COMMAND UP/DOWN
