Plexamp Mix Builder include Genre's & Moods
There have been a couple times where I have wished I could select two or more moods/genres to listen to.
But I feel like it would make sense to include this in the Mix Builder feature!
(Not sure if this is the correct board to post a Plexamp feature request)
You can do this with a library filter; just hit the filter button and add as many album or artist genres you want and then hit shuffle!
Oh I see! Thanks so much!
Is there be any way to change the filter from from using AND to OR logic?
yes, MATCH ANY and MATCH ALL, tap to change it.
