PlexAmp No Longer Plays Music
Up until 2 or so weeks ago, everything was working fine, then all of a sudden when I go to play a playlist its skipping through a bunch of them before getting to a song it will play. Other playlists it just skips through all of the songs.
If I open these playlists in plex they still work just fine, and used to on plexamp (windows or andriod). Now it just skips past most of my music that is local.
Check your music library settings on the server to see if “Store Track Progress” is enabled.
Edit the library and head to the Advanced tab. If “Store track progress” is enabled, disable it. You may need to restart Plexamp for the change to take effect.
If that’s not the problem, you may need to post your Plexamp logs showing the problem for someone to take a look at.
“Store Track Progress” is disabled on the Music library.
Attached are the logs from PlexAmp on my Andriod device.
222440458907435.zip (598.3 KB)
You were being bitten by a bug which was fixed in the newest release.
