Server Version#: 1.40.1.8251
Plexamp Version#: 4.10.1
I use plexamp ran from my shield 2019 pro.
The media server did an update and now I cannot access my library from outside my home WiFi network.
I have rebooted my router, my shield, and cycled remotes access, and also cycled the media server within the old app on the shield?
Is this specifically only Plexamp or are other Plex client types also affected?
Hi thanks for the reply. Just checked and itâs also affecting the Plex amp, but donât know the status of this prior to the server update, as never use it.
I have downloaded some logs, but canât see how to attach them from here?
Is this a typo?
You have titled this thread âPlexamp not working outside of homeâŠâ
Sorry yes, itâs also affecting the regular Plex app, was what I meant to say. Sorry. Plexamp is my concern
Hi Thanks,
So if I can get the beta update, it should cure?
Itâs no longer beta now.
Just need to wait until it appears in the app store.
Ok, thanks.
Is this a known concern? Apologies, I canât determine from the release notes. Is there a timeline?
Iâm not sure what you are asking.
No worries
Is my concern a known one?
Is there a timeline for a full release on the play store?
The release time is outside of Plexâs hands. It is up to Google when they are making it available. Usually they do it in waves, so that not every device in the world tries to update at the same time.
The remote connection being dropped after an upgrade of the server may or may not be connected to the fix for the nVidia Shield that is mentioned in the release notes.
Ok, thanks for your help.
I will raise continue the thread or raise a new one when the server is updated.
I hope it is cured. If I had Plex pass, would this make any difference to this concern or how it is handled? I have been toying with purchasing when there is an offer on, but previously I havenât seen the benefits I would make use of.
Best Regards
Nick
Plex Pass or not doesnât make any difference in regard to support.
Ok, thanks.
Is it possible to roll back to a previous version?
Unfortunately I donât know. With an app store in the game, things like this are usually impossible or prohibitively complicated.
Ok, thanks.
Do you know the version number of the previous full release of the shield media server, so I can investigate myself?
I donât know that. I only know that there were some issue with the builds for the Shield, so that these releases were recently much less frequent than for the other platforms.
Just be patient and wait for the release to come through. Should be sometime today in my experience.
Thank you. Fingers crossed it wonât be too long.
I appreciate your help and guidance
