PlexAmp Pauses Immediately After Pressing Play
Server Version#: 1.32.5.7349
Player Version#: 4.8.3
Whatever I play on Plexamp, the player immediately pauses without any of the track reaching my earbuds. I can see the track progressing maybe 0.5 to 1 second each time I press play. All tracks and playlists play perfectly from the web app.
I have cleared cache, no difference. Cleared data and logged in again, no difference.
Any suggestions?
Where is Plexamp installed/running?
Are you “casting” to another device (wireless speakers, or Chromecast etc.)?
Are you using wireless headphones?
(Plexamp logs also helpful)
I have had this happen, too, when just starting up on my journey. I start the car (or motorcycle helmet) and, for whatever reason, PlexAmp does not begin playing right away so I press play and it pauses after a second or two and I have to hit play, again.
I lost logs due to clearing data and cache…
I was listening on Google Pixel Buds Pro and I think that is the source of the issue. I connected to my car later in the day and it worked fine. It also then worked fine when my Pixel buds were reconnected.
