Server Version#: 1.27.0.5889 (linux / docker)
Player Version#: plexamp-appimage 4.2.2-1
Sonos: S2 version 14.8.1
At some point yesterday, my plex / sonos integration stopped working correctly. When I cast albums from Plexamp to the sonos, everything seems to work fine at first, but then playback seems to automatically pause after about 13 seconds or so. I can then unpause it, but then it pauses itself again about 13 seconds later.
Trying to reauthenticate to Plex in the Sonos app I got a message about checking my network connection (which is fine).
I didn’t see anything obviously relevant in my server logs, though there was this http error where my server got a 403 on the below URL:
I am getting this issue with both Plexamp as well as the Plex app on iOS. I also experienced issues using the Sonos app > Plex. I have not checked casting to Sonos with the Android app but expect there will also be an issue. Leads me to suspect that @elan is correct and it may be a Plex side server issue with Sonos service. Thanks.
Thanks for taking a look. Attached are my Plexamp logs from MacOS. I also get the same behavior when using Plexamp for Android and Plexamp for Linux (on Manjaro).
I haven’t really looked at my Plexamp logs before. There is one line Jun 11, 2022 17:34:56.046 [Javascript] INFO - Player: State transition paused -> stopped for source RINCON_542A1BF3724E01400:273377789 ID undefined. that stands out, but no obvious errors.
Also captured in this log is some of the weird bahvior that seems to occur after playback stops, when Plexamp sort of bounces back and forth between the library view and the player view.
Glad I’m not alone on this. I have the behavior as well on Plex app for Windows and Mac (as well as iOS and Android). I rolled back servers to 1.26.2.5797-5bd057d2b and got the same error all around. The symptom for Plex App on Windows and Mac is that the play bar at bottom disappears and then re-appears randomly every several seconds, but the stream of music continues in (most, but not all) cases.
Not to beat a dead horse, but unless I’m misreading it, I didn’t see any 500 errors in the logs I posted earlier. Every request to sonos.plex.tv seemed to come back with a 200 or 204 response code. (There are some other requests that seem to indicate negative response codes, which I assume is some internal encoding, but they don’t look overtly sonos-related.) Any chance you could point me to the specific lines? Not a big deal if you have better things to do though.
This has started happening for me again after being fixed for the last week. It’s happening less often, but it has happened twice in the last 10 minutes here.
