Plexamp problems
Hoping some, one can advise or assist. Now that Plexamp is working on AA, I’ve been giving it a run and it worked perfect the first time; now however every time i use it, the music stops or appears to mute after ( approximately 30 seconds). The car screen still shows the track as playing, however after an undetermined time the play button shows. I hit the play button and it starts from where the mute happened. I have rebooted the phone, which hasn’t helped. phone signal is good.
Post logs after it happens so we can have a look. Advanced > Debugging in settings.
hiya,
Ok, would these be the logs from the android device?
Yes, from within Plexamp.
Hiya
does this work?
329826541406358.zip (49.6 KB)
@Garden2512
Did you ever get this resolved? Having the same issue.
