Plexamp - Recently Added Playlist : Adjust Time Frame
Is there an option in Plexamp (or possible on the Plex server) to adjust the time frame for items to be considered “Recently Added”?
For example, when using the Recently Added playlist in Plexamp, I would like to be able to adjust this to “Last X Days”, “Last Week” or “Last Month.”
Edit: I was able to create Smart Playlists using the Plex Web Interface.
Sort of, and you may have found this already.
In Plexamp if you go into the albums view of your library, click on the filter icon.
You can the add a rule type “Added” in the album section and choose the “within” option to meet your needs. This then creates a narrower view of your albums.
I’m not sure if this is helpful if you need it to be in your recently added playlist but might be worth playing with.
