Plexamp version 4.6.0 [Mod-Edit: on Android mobile]
i have same problem, crashes on open after latest update to 4.6.0.
was working fine previously, this is on phone without Google Play Services. partial log below:
type: crash
osVersion: google/sunfish/sunfish:13/TP1A.221105.002/2022112500:user/release-keys
package: tv.plex.labs.plexamp:324000643
process: tv.plex.labs.plexamp
processUptime: 868 + 502 ms
java.lang.RuntimeException: Unable to start activity ComponentInfo{tv.plex.labs.plexamp/com.plexamp.MainActivity}: java.lang.RuntimeException: com.google.android.gms.cast.framework.ModuleUnavailableException: com.google.android.gms.dynamite.DynamiteModule$LoadingException: No acceptable module com.google.android.gms.cast.framework.dynamite found. Local version is 0 and remote version is 0.
at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:3677)
at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:3814)
at android.app.servertransaction.LaunchActivityItem.execute(LaunchActivityItem.java:101)
at android.app.servertransaction.TransactionExecutor.executeCallbacks(TransactionExecutor.java:135)
at android.app.servertransaction.TransactionExecutor.execute(TransactionExecutor.java:95)
at android.app.ActivityThread$H.handleMessage(ActivityThread.java:2309)
at android.os.Handler.dispatchMessage(Handler.java:106)
at android.os.Looper.loopOnce(Looper.java:201)
at android.os.Looper.loop(Looper.java:288)
at android.app.ActivityThread.main(ActivityThread.java:7904)
at java.lang.reflect.Method.invoke(Native Method)
at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:548)
at com.android.internal.os.ExecInit.main(ExecInit.java:49)
at com.android.internal.os.RuntimeInit.nativeFinishInit(Native Method)
at com.android.internal.os.RuntimeInit.main(RuntimeInit.java:355)
Caused by: java.lang.RuntimeException: com.google.android.gms.cast.framework.ModuleUnavailableException: com.google.android.gms.dynamite.DynamiteModule$LoadingException: No acceptable module com.google.android.gms.cast.framework.dynamite found. Local version is 0 and remote version is 0.
at com.google.android.gms.cast.framework.CastContext.getSharedInstance(com.google.android.gms:play-services-cast-framework@@21.2.0:11)
at tv.plex.labs.player.AudioMainActivity.onCreate(AudioMainActivity.java:42)
at com.plexamp.MainActivity.onCreate(MainActivity.java:34)
at android.app.Activity.performCreate(Activity.java:8337)
at android.app.Activity.performCreate(Activity.java:8316)
at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1389)
at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:3658)
... 14 more
Caused by: com.google.android.gms.cast.framework.ModuleUnavailableException: com.google.android.gms.dynamite.DynamiteModule$LoadingException: No acceptable module com.google.android.gms.cast.framework.dynamite found. Local version is 0 and remote version is 0.
at com.google.android.gms.internal.cast.zzad.zzf(com.google.android.gms:play-services-cast-framework@@21.2.0:7)
at com.google.android.gms.internal.cast.zzad.zza(com.google.android.gms:play-services-cast-framework@@21.2.0:1)
at com.google.android.gms.cast.framework.CastContext.<init>(com.google.android.gms:play-services-cast-framework@@21.2.0:4)
at com.google.android.gms.cast.framework.CastContext.getSharedInstance(com.google.android.gms:play-services-cast-framework@@21.2.0:10)
... 20 more
Caused by: com.google.android.gms.dynamite.DynamiteModule$LoadingException: No acceptable module com.google.android.gms.cast.framework.dynamite found. Local version is 0 and remote version is 0.
at com.google.android.gms.dynamite.DynamiteModule.load(com.google.android.gms:play-services-basement@@18.1.0:67)
at com.google.android.gms.internal.cast.zzad.zzf(com.google.android.gms:play-services-cast-framework@@21.2.0:2)
... 23 more
Same issue with both android phone & tablet. Plexamp can’t find either of my servers while regular Plex continues to work fine
After the 4.6.0 update on Android, Plexamp crashes immediately. I have a Pixel 6a running GrapheneOS without Google play services.
The 4.6.0 AppImage on Linux is working fine by the way.
type: crash
osVersion: google/bluejay/bluejay:13/TP1A.221105.002/2022112500:user/release-keys
processUptime: 178 + 191 ms
... 14 more
... 20 more
... 23 more
For now, I have uninstalled Plexamp and reinstalled 4.5.3 version code 324000624 and it’s working fine again. Please let me know when a fix is available so I can update again.
Thanks for the reports. This will be fixed in 4.6.1.
