Graphene OS and Plex Dash
Just installed Graphene OS on a Pixel 7 pro and the plex dash crashes as soon I open it. Even with Google Framework installed. Plex itself runs just fine. Here are the logs:
osVersion: google/cheetah/cheetah:13/TQ3A.230605.012/2023062800:user/release-keys
package: tv.plex.labs.dash:324000050
process: tv.plex.labs.dash
processUptime: 717 + 255 ms
java.lang.RuntimeException: com.google.android.gms.dynamite.DynamiteModule$LoadingException: No acceptable module found. Local version is 0 and remote version is 0.
	at com.google.android.gms.internal.cast.zze.zzf(Unknown Source:51)
	at com.google.android.gms.internal.cast.zze.zza(Unknown Source:1)
	at com.google.android.gms.cast.framework.CastContext.<init>(Unknown Source:37)
	at com.google.android.gms.cast.framework.CastContext.getSharedInstance(Unknown Source:6)
	at com.reactnative.googlecast.GoogleCastModule$16.run(GoogleCastModule.java:580)
	at android.os.Handler.handleCallback(Handler.java:942)
	at android.os.Handler.dispatchMessage(Handler.java:99)
	at com.facebook.react.bridge.queue.MessageQueueThreadHandler.dispatchMessage(MessageQueueThreadHandler.java:27)
	at android.os.Looper.loopOnce(Looper.java:201)
	at android.os.Looper.loop(Looper.java:288)
	at android.app.ActivityThread.main(ActivityThread.java:7937)
	at java.lang.reflect.Method.invoke(Native Method)
	at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:548)
	at com.android.internal.os.ExecInit.main(ExecInit.java:49)
	at com.android.internal.os.RuntimeInit.nativeFinishInit(Native Method)
	at com.android.internal.os.RuntimeInit.main(RuntimeInit.java:355)
Caused by: com.google.android.gms.dynamite.DynamiteModule$LoadingException: No acceptable module found. Local version is 0 and remote version is 0.
	at com.google.android.gms.dynamite.DynamiteModule.load(Unknown Source:8)
	at com.google.android.gms.internal.cast.zze.zzf(Unknown Source:41)
	... 15 more
Isn’t possible to have it on this kind of operating system?
I am having the same issue. Plex and Plexamp both run perfectly, but Plexdash is crashing on launch with the same traceback.
This should be resolved in the next version.
Dash 2.0 should have the fix for this:
Please let me know if you’re still having trouble!
