OK I just download the plex app for my google tv. I will install later. This is the same old thing I keep asking.OK here is is: Can some please post exactly what I need to get PLexbmc working.
I have plexbmc 3.2.2 and plexmbc helper 3.1.4 or 3.1.5 installed in my xbmc.
That in itself is enough to test PlexBMC, though in a limited fashion, similar to how you'd use other video add-ons in XBMC.
You just need to configure PlexBMC enough to reach your PMS server.
I also have amber skin and quartez skin.
And those are what will allow you to let PlexBMC take over as your main XBMC media source, almost like a 'real' Plex client.
The key to this is the 'Go Plex' command of those two skins.
NB: I'm assuming you mean the 'PlexBMC' version of the Quartz skin, since there have been Quartz releases without PlexBMC features too.
Question 1)What skin(s) does plexbmc work best with in xbmc?
To my knowledge only those two skins have been fully adapted to allow PlexBMC to work like a real Plex client.
With other skins you'll frequently 'fall out' of the PlexBMC add-on, and have to relaunch it again and again.
If someone got a windows 7 pc with plexbmc 3.2.2 configured and working,can you please post me the those setting or the setting that will get plexbmc working.
Assuming you use XBMC on a Win7 PC (which I don't), its configuration should be near identical to other platforms, which is what I will describe here.
Question 2) Show me the order to install this if it matters?
Since my usual install order differs from that of Pecinko (who is an expert), the order clearly doesn't matter much.
XBMC itself must obviously come first though, since all add-ons are installed through it.
What I do on each of my Android devices is to first install an appropriate XBMC version on it (some are device specific), and then I install the add-ons from ZIP files in the following order. (For this I use the submenu "System" > "Settings" > "Add-ons" > "Install from Zip file".)
1: plugin.video.plexbmc-3.2.2.new.frodo.zip
2: script.plexbmc.helper-3.1.4.zip
3: skin.amber-master.zip
4: skin.quartz3.plexbmc-0.7.5.zip
NB: The skins take a long time to install, and their install always ends with a question whether you want to activate the skin.
I always wait for that query before attempting further commands, and I always decline the query as I prefer normal activation through the settings menu. So I perform the entire installation sequence while in the original 'Confluence' skin.
After this I seek out the PlexBMC add-on in the list of 'Enabled Add-ons' and give it the basic configuration needed to reach the PMS server. There are different ways of doing this, but I always do it by disabling local server search and instead establishing the connection through myPlex login (by specifying the username and password for this). Here again my method differs from what Pecinko described, as Plex has considerable 'leeway' in how the server is used.
It's only after I have set all the above up that I go into the 'Appearances' section of the XBMC settings and there activate the 'Amber' skin (previously I used Quartz, but I prefer the Amber skin nowdays). And then I use its "Go Plex" command and leave it so.
Since my entire media collection is scanned by my PMS server, my only use for XBMC in non-Plex mode would be for media files not yet added to the Plex library, or for some of the XBMC channels. But I already have lots of 'channels' in Plex itself or as standard Android apps (like Navi-X).
Question 3)How to I configure plexbmc helper so that it works or how to config it so that plexbmc works
I'm not sure exactly what this 'helper' is doing, but I have noticed that its error messages tend to stop if I activate the 'Web Server' in the 'Services' settings of XBMC itself. No detailed config seems necessary, but simply enabling that server so that the helper can use HTTP commands to control XBMC. (Odd way of doing it IMO, but as long as it does work it's all good...)
If you do the above as described then you should be able to make it work, since that has worked for me on several devices.
Best regards: dlanor
