Delete everything even old Pms apps, plexconnect, installers, plists, certs, etc. Use my signature to install on osx. I’ve ran on iOS 5.02 and up on 10.8.5. Save your shsh if possible using Ifaith, windows only I think, if u don’t have windows install windows using virtual box on osx then link your USB to virtual box. Heard issues with ios6 on atv subtitles and playback issues, disregard if you save your .shsh’s within apples signing window.
after finished doing what wahlman said, i recommend updating to ios 6
Thanks, Wahlman. I've done most of what you said in your other post, regarding the PlexConnect install. I don't need the auto-launch part yet, as it's not working when run from Terminal.
The DNS redirection is working, but it's just not sending the Trailers app to the PlexConnect webserver:
What steps have you done to troubleshoot so far.
As far as I know the change for trailer requiring https was across all ATV firmware so you will need the latest plexconnect as well as certificate etc. the settings file you provided does not have a lot of settings.
Can you try the latest plexconnect allow it to create a new settings.cfg and then install the certificate following the standard steps and then post the content of the log file (via paste bin link) not just the contents of the terminal window.
I tried lots of different combinations of settings in the CFG file, none of which worked. I felt that I should be able to use the old CFG file and the old 0.1 PlexConnect release, since my iOS was so old. Not quite sure I buy that part about ATV switching to HTTPS without an iOS/FW update. I don't see how that's possible.
Anyway, my ATV3 worked just fine with the latest PlexConnect, so I knew it was something between the ATV2, the old iOS, and the old PlexConnect. I bit the bullet and jumped to iOS 6 on the ATV2, and PlexConnect is working fine with it now! :D
Glad you got it try my 2nd link for autostart. Plexconnect should always be the latest master from here reguardless of ios version espically since trailers.pem is now needed, that was prob your issue all along:
https://github.com/iBaa/PlexConnect
WIKI says:
Deprecated: v0.1 does not feature the SSL enhancement, that Apple forced on aTV 27Aug. This release is of no use any more...
