Plexconnect connecting but not loading any content
Hello All, I have been using my plex with my ATV3 for a while. Lately my ATV3 will connect from the Trailers icon to my plex server and I can see it running in my Windows command prompt, and I also see it open up in the Trailers app, however no content loads. I can click on the movies or tv show and it will go that screen and show blank icons of my content on my server. If I try to play any of the blank icons it gives me a "accessing trailer". I know I have done everything correctly becuase it was working perfectly before for the past 4 months. I don't know what happened between my computer and ATV but it won't connect. I have noticed that the rest of my apps on the ATV are really slow as well.
Here is what I have:
Windows 7 running latest Plex Server
ATV with latest firmware
Latest version of plexconnect running according to the correct setup with python and such
Also to fight the slowness I changed the DNS from Google's to my local DNS per instructions from site (due not this worked for a while, I changed back to the Google DNS but still no luck)
Below is what my CMD is giving me, I can't figure out why I am running into this issue? Has anyone else run into this issue where the Trailer app loads Plex but the content is blank and won't load as well as the rest of the apps are slow.
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation.  All rights reserved.
C:\Windows\system32> cd \program files
C:\Program Files> cd plexconnect
C:\Program Files\PlexConnect>plexconnect.py
21:48:50 PlexConnect: ***
21:48:50 PlexConnect: PlexConnect
21:48:50 PlexConnect: Press CTRL-C to shut down.
21:48:50 PlexConnect: started: 21:48:50
21:48:50 PlexConnect: Version: 0.3.1+
21:48:50 PlexConnect: Python: 2.7.6 (default, Nov 10 2013, 19:24:24) [MSC v.1500
 64 bit (AMD64)]
21:48:50 PlexConnect: Host OS: win32
21:48:50 PlexConnect: IP_self: 192.168.1.2
21:48:50 DNSServer: started: 21:48:50
21:48:50 DNSServer: ***
21:48:50 DNSServer: DNSServer: Serving DNS on 192.168.1.2 port 53.
21:48:50 DNSServer: intercept: ['trailers.apple.com'] => 192.168.1.2
21:48:50 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld
.apple.com.edgesuite.net'] => 127.0.0.1
21:48:50 DNSServer: forward other to higher level DNS: 75.75.75.75
21:48:50 WebServer: started: 21:48:50
21:48:50 WebServer: ***
21:48:50 WebServer: WebServer: Serving HTTP on 192.168.1.2 port 80.
21:48:50 WebServer: WebServer: Serving HTTPS on 192.168.1.2 port 443.
21:49:34 DNSServer: DNS request received!
21:49:34 DNSServer: Source: ('192.168.1.9', 63391)
21:49:34 DNSServer: Domain: trailers.apple.com
21:49:34 DNSServer: ***intercept request
21:49:34 DNSServer: -> DNS response: 192.168.1.2
21:49:35 WebServer: serving /js/application.js
21:49:35 WebServer: serving .xml: /
21:49:35 ATVSettings: add section DY5KDDHXFF54
21:49:35 PlexAPI: ***
21:49:35 PlexAPI: looking up Plex Media Server
21:49:36 PlexAPI: GDM: Servers discovered: 1
21:49:36 PlexAPI: Servers (local+MyPlex): 1
21:49:36 WebServer: serving .xml: /PlexConnect.xml
21:49:36 WebServer: serving /js/utils.js
21:49:38 WebServer: serving .xml: /library/sections
21:49:38 WebServer: serving /js/utils.js
21:49:45 WebServer: serving /js/sectionHoldSelect.js
21:49:45 WebServer: serving .xml: /library/sections/1/recentlyAdded
21:49:48 WebServer: serving .xml: /library/sections/1
21:49:48 WebServer: serving /js/utils.js
21:49:49 WebServer: serving /js/updateXML.js
21:49:49 WebServer: serving .xml: /library/sections/1
21:49:51 WebServer: serving /js/utils.js
21:49:51 WebServer: serving /js/updateXML.js
21:49:51 WebServer: serving /js/settings.js
21:50:18 WebServer: serving .xml: /channels/all
21:50:18 WebServer: serving /js/utils.js
21:50:19 WebServer: serving .xml: /channels/all
21:50:19 WebServer: serving /js/utils.js
21:50:20 WebServer: serving .xml: /library/sections
21:50:20 WebServer: serving /js/utils.js
21:50:21 WebServer: serving /js/sectionHoldSelect.js
21:50:21 WebServer: serving /js/settings.js
21:50:22 WebServer: serving .xml: /
21:50:22 WebServer: serving .xml: /channels/all
21:50:22 WebServer: serving /js/utils.js
21:50:23 WebServer: serving /js/settings.js
21:50:24 WebServer: serving .xml: /
21:50:25 WebServer: serving /js/utils.js
21:50:37 DNSServer: DNS request received!
21:50:37 DNSServer: Source: ('192.168.1.9', 62152)
21:50:37 DNSServer: Domain: trailers.apple.com
21:50:37 DNSServer: ***intercept request
21:50:37 DNSServer: -> DNS response: 192.168.1.2
21:50:37 WebServer: serving /js/settings.js
I had an issue with slow response and blank icons a while back and I had to do an optimize on plex web
Thanks, I tried this as well with no luck, appreciate the response though. This one really boggles me, I can't figure out the disconnect
I am also having problems with PlexConnect not loading posters and showing a yellow warning triangle when i try to play movies on my apple TV 3. I'm using firmware 6.1.1 because according to the documents the latest firmware 7 is not supported https://github.com/iBaa/PlexConnect/wiki/Supported-Apple-TV-devices-and-firmwares. I tried to use a lower firmware but Itunes wont let me install lower than 6.1.1. I am running the latest version of plex server and plexconnect.
