PlexConnect device authentication issues
I have 2 Apple TVs (3rd generation) that are connected to PMS on a Windows 7 box via PlexConnect (0.4-dev).
Both devices can sign into MyPlex successfully and discover the Plex server but get authentication issues when trying to access the shared libraries. I have restarted the server as well as the Apple TVs and signed in/out on multiple occasions with no luck.
If I remove the authenticate on network option I can see all the libraries but I want the specific-per-user setups.
Looking back, like an idiot, I went and removed all devices from the Plex setup page that I thought were old and not used anymore. It turns out that 2 of these devices were my ATVs.
How do I *add* the devices to Plex so that the devices authenticate correctly? I have deleted the config file for PlexConnect and had a new one recreated but this does not help.
Thanks.
Log out and back into my plex that will cause them to authenticate again
I've tried that without success.
I have revoked the shares and reshared the libraries and I still get "PlexAPI: No Response from Plex Media Server",""PlexAPI: We failed to reach a server. Reason: Unauthorized".
I have logged in as the main user on PlexPass succesfully with the same error.
There is an iOS device showing in the device list though.
When trying what? What was the aTV request plus the PlexConnect request right before that message?
19:06:04 PlexConnect: started: 19:06:04
19:06:04 PlexConnect: Version: 0.4-dev
19:06:04 PlexConnect: Python: 2.7.3 (default, Apr 10 2012, 23:31:26) [MSC v.1500 32 bit (Intel)]
19:06:04 PlexConnect: Host OS: win32
19:06:04 PlexConnect: IP_self: 192.168.2.160
19:06:04 DNSServer: started: 19:06:04
19:06:04 DNSServer: ***
19:06:04 DNSServer: DNSServer: Serving DNS on 192.168.2.160 port 53.
19:06:04 WebServer: started: 19:06:04
19:06:04 WebServer: ***
19:06:04 WebServer: WebServer: Serving HTTP on 192.168.2.160 port 80.
19:06:04 WebServer: WebServer: Serving HTTPS on 192.168.2.160 port 443.
19:06:11 PlexAPI: ***
19:06:11 PlexAPI: looking up Plex Media Server
19:06:12 PlexAPI: GDM: Servers discovered: 1
19:06:12 PlexAPI: Servers (local+MyPlex): 1
19:06:12 PlexAPI: No Response from Plex Media Server
19:06:12 PlexAPI: We failed to reach a server. Reason: Unauthorized
19:06:15 PlexAPI: No Response from Plex Media Server
19:06:15 PlexAPI: We failed to reach a server. Reason: Unauthorized
19:06:44 PlexAPI: MyPlex Sign In successfull
19:06:44 PlexAPI: ***
19:06:44 PlexAPI: looking up Plex Media Server
19:06:45 PlexAPI: GDM: Servers discovered: 1
19:06:46 PlexAPI: Servers (local+MyPlex): 1
19:06:47 PlexAPI: No Response from Plex Media Server
19:06:47 PlexAPI: We failed to reach a server. Reason: Unauthorized
19:06:58 PlexAPI: No Response from Plex Media Server
19:06:58 PlexAPI: We failed to reach a server. Reason: Unauthorized
It's when I sign in and it wants to load the main screen and it's when I switch between Playlists/Library/Channels/Shared Libraries.
Webserver: serving .xml: /PlexConnect.xml
Webserver: serving js/utils.js
Webserver: serving .xml: /library/sections
You have a Plexpass so it might also be worth asking in the "ask a ninja" sub forum as it seems to be a PMS issue from you removing the authorized devices (maybe it keeps a blacklist by eg MAC address that can be edited).
I removed the extra users i had made. And that made it work. No more unauthorized...
Can you explain what you did to make this work?
