Should TV Show (season and series) and Movie Posters be displaying? right now the descriptions of Movies and TV Shows are coming up fine, but Images are not displaying at all. Video content is working. I have this running on my Mac with the latest PlexPass PMS release .27.16? Let me know if there are any logs/details that could help with troubleshooting.
(I'm accessing my PMS remotely, I have the DNS response to my public IP address of the PMS server, HTTP process is running on same machine)
I can navigate and play videos just fine.
Here is log of navigating to a TV Show -> SEason -> Selecting a Show -> Displaying the Pre-play screen (This is where you see those errors of pulling actor info Line 40)
Nothing else seems to point towards a problem pulling images, except maybe the request itself isn't working. I tried browsing using the plex web app and everything works fine.
Update: Nevermind, this probably isn't it, PlexConnect is running on my local network and would have access to the metadata url (as shown with the 200 Return codes in the logs), plexconnect then would take this data and massage it to the proper XML format the ATV is expecting. Something else must be happening for images to not display
This is true for metadata like summary, actors,...
The pictures/thumbnails are NOT massaged in to the XML file, you only find their URLs. And this URL should either point to PMS doing some transcoding or directly to the source, wherever it might come from.
Basically this is the same process as playing your media files (movies, TV shows). Question to this... do you have to transcode this media or is it direct streamed. If the latter... try to do a "forcetranscode" and see if it still works.
I guess I need to some how see the XML with the image URLs that's ultimately returned to the ATV. Not quite obvious how to get to this yet. Ideas?
According to XML yes it is delivering URLs to the image just like you mentioned, the Image URL is to actually transcode the image from the PMS. Which the transcoding part is not a problem and is doing as it should.
So the issue once again is the fact that I'm outside my home network. The PMS will not allow the URL to be accessed outside home network. If I use this url within my home network I can pull up the image.
I think I might be having the same issue as you, so I tried changing this setting http://i.imgur.com/jm8CLYj.png . It didn't help me. How about you?
Yup, I ended up in the same place as well, but the PMS seems to be ignoring what I have set there. I also tried disabling remote security from the plex wiki instruction, no dice there as well. There has to be some way to disable remote security...
Resolved the issue, and got Image to load! The problem was because you need to include the netmask so your-remote-Ip-that-needs-access/255.255.255.0,ip-of-machine-running-pms/255.255.255.0,127.0.0.1/255.255.255.0 should do it.
