Hi all,
I have seen a few other post with similar issues but none on the proposed fixes have worked to date. First thing is first:
Model and firmware: ATV3 (Firmware 5.3 (6105)
DNS Server on ATV: 192.168.1.133
Device and OS running PlexConnect: PC running Windows 7 (SP1)
Local IP of device running PlexConnect: 192.168.1.133
Device and OS running PMS: PC running Windows 7 (SP1)
PMS Version Number: 0.9.8.4.125-ffe2a5d
Local IP of device running PMS: 192.168.1.133
PlexConnect details: Most recent iBaa version fully updated as of 17 August 2013
Content of Settings.cfg:
[PlexConnect]
logpath = .
enable_dnsserver = True
ip_webserver = 0.0.0.0
prevent_atv_update = True
enable_plexconnect_autodetect = True
port_pms = 32400
port_webserver = 80
ip_plexconnect = 0.0.0.0
ip_dnsmaster = 8.8.8.8
loglevel = High
ip_pms = 192.168.178.10
enable_plexgdm = True
Detail on a media file: http://pastebin.com/zkeraS35
PlexConnect log: http://pastebin.com/1C38YwmC
Description of the issue: I have just set up my PlexConnect using Python 2.7.5 and the last PlexConnect from iBaa. I have followed the installation guide and PlexConnect is visible when I go into trailers (albeit everything appears to be loading slowly, potentially because it would be the first time attempting to load metadata). There is, however, no metadata visible for any of the shows (television shows only at this stage) and if I attempt to play one of the media files (.avi and .mkv) I receive the following error: "An error occurred loading this content. Try again later"
I have also played around with the ip_dnsmaster to mirror the ATV/PMS IP and have tried setting enable _lexdgm to FALSE. This has not made any differences, in fact when enable_lexdgm is set to FALSE I am unable to connect to PlexConnect at all. I have also switched off the server computer, router and ATV numerous but this has not worked either.
Computer and ATV both connected to router using Cat6.
I would welcome any thoughts on what to try from here.
Cheers,
Tom
