PlexConnect not working even after new ATV work around
institute: The error "Failed to access certificate: *" is logged always - in case of the error that is.
steve:
>> I'm trying to paste in an image, but I'm having difficulty.  My Netgear router, in the services, has entry #8 for port 443.  Would this be stopping it from working?
I don't know...
OK. I was just thinking that during this transition it may be more efficient to have an explicit reference to the cert file path in the normal log setting so we know for a fact that people are up to date. It will become less of an issue as more time passes, of course.
Yeah... we could probably add something.
http://langui.sh/2013/08/27/appletv-ssl-plexconnect/
good,
in spanish
http://digitalhitech.wordpress.com/2013/09/02/plex-on-atv3/
- Ignore below, meant to start new post.
I followed the instructions carefully and read through the forum but still get the 'trailers not available' message.
Mac OS X 10.7.5
Python 2.7.5 (v2.7.5:ab05e7dd2788+
Atv 5.3 (6105)
Latest Plex Connect version
Plex Media Server 0.9.8.6.175
Navigating to https://192.168.1.8:443 results in 'certificate is unknown' message (points to the certificate I created and put on ATV)
LogFile
17:58:42 PlexConnect: ***
17:58:42 PlexConnect: PlexConnect
17:58:42 PlexConnect: Press CTRL-C to shut down.
17:58:42 PlexConnect: started: 17:58:42
17:58:42 PlexConnect: IP_self: 192.168.1.8
17:58:42 DNSServer: started: 17:58:42
17:58:42 DNSServer: ***
17:58:42 DNSServer: DNSServer: Serving DNS on port 53.
17:58:42 DNSServer: intercept: ['trailers.apple.com', 'atv.plexconnect'] => 192.168.1.8
17:58:42 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
17:58:42 DNSServer: forward other to higher level DNS: 8.8.8.8
17:58:42 WebServer: started: 17:58:42
17:58:42 WebServer: ***
17:58:42 WebServer: WebServer: Serving HTTP on 0.0.0.0 port 80.
17:58:42 PlexGDM: ***
17:58:42 PlexGDM: looking up Plex Media Server
17:58:43 WebServer: started: 17:58:43
17:58:43 WebServer: ***
17:58:43 WebServer: WebServer: Serving HTTPS on 0.0.0.0 port 443.
17:58:44 PlexGDM: servers discovered: 1
17:58:44 XMLConverter: PlexGDM - PMS: 192.168.1.8:32400
17:59:12 DNSServer: DNS request received!
17:59:12 DNSServer: Source: ('192.168.1.9', 58527)
17:59:12 DNSServer: Domain: trailers.apple.com
17:59:12 DNSServer: ***intercept request
17:59:12 DNSServer: -> DNS response: 192.168.1.8
18:03:43 DNSServer: DNS request received!
18:03:43 DNSServer: Source: ('192.168.1.9', 57810)
18:03:43 DNSServer: Domain: mesu.apple.com
18:03:43 DNSServer: ***restrain request
18:03:43 DNSServer: -> DNS response: 192.168.1.8
Settings.cfg
[PlexConnect]
logpath = .
enable_dnsserver = True
ip_webserver = 0.0.0.0
prevent_atv_update = True
port_dnsserver = 53
enable_plexconnect_autodetect = True
port_pms = 32400
port_webserver = 80
ip_plexconnect = 0.0.0.0
certfile = ./assets/certificates/trailers.pem
ip_dnsmaster = 8.8.8.8
loglevel = Normal
ip_pms = 192.168.178.10
enable_plexgdm = True
port_ssl = 443
Tried both the absolute and complete path. Full restart of Mac & ATV before after changing settings; same result.
any clue?
Sounds like issues with te certificate in the atv. Delete the current. Certificate/profile and redo those steps
Life saver!
Now works like a dream. Many thanks
EDIT: SOLVED motherf..-.- trailers.pem was d/led and used on the iMac while trailers.cer was d/led on my MacAir and sent to aTV; transferred  .pem that came with .cer on my air to my imac and it worked.. i can sleep now.
Mac OS X: 10.6.8
Python: 2.7.5
ATV: 5.2.1
PlexConnect: Latest; Master
PMS: 0.9.8.6.175
It was working perfectly fine when i set it up on Windows 7 until I changed it back to my older iMac (DHCP reservation and all configured again on the Mac)
[] I've deleted and redid the steps for Certificate/profile following -> http://langui.sh/2013/08/27/appletv-ssl-plexconnect/ - Fail
[] Restarted the mac and atv - Fail
[] Tried both the default "./assets/certificates/trailers.pem" and absolute "/Users/Reira/Documents/PlexConnect-master/assets/certificates/trailers.pem" filepath. - Fail
Always ending up with "Trailer is unavailable..."
Typing in "10.0.1.10:80" returned:
Error response
Error code 403.
Message: Not Serving Client 10.0.1.10.
Error code explanation: 403 = Request forbidden -- authorization will not help.
Typing in "10.0.1.10:443" returned:
a no connection page
Log
05:04:28 PlexConnect: ***
05:04:28 PlexConnect: PlexConnect
05:04:28 PlexConnect: Press CTRL-C to shut down.
05:04:28 PlexConnect: started: 05:04:28
05:04:28 PlexConnect: IP_self: 10.0.1.10
05:04:28 DNSServer: started: 05:04:28
05:04:28 DNSServer: ***
05:04:28 DNSServer: DNSServer: Serving DNS on 10.0.1.10 port 53.
05:04:28 DNSServer: intercept: ['trailers.apple.com', 'atv.plexconnect'] => 10.0.1.10
05:04:28 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
05:04:28 DNSServer: forward other to higher level DNS: 8.8.8.8
05:04:28 WebServer: started: 05:04:28
05:04:28 WebServer: ***
05:04:28 WebServer: WebServer: Serving HTTP on 10.0.1.10 port 80.
05:04:28 PlexAPI: ***
05:04:28 PlexAPI: looking up Plex Media Server
05:04:28 WebServer: WebServer: Serving HTTPS on 10.0.1.10 port 443.
05:04:29 PlexAPI: servers discovered: 1
05:04:29 XMLConverter: PlexGDM - PMS: 10.0.1.10:32400
05:04:34 DNSServer: DNS request received!
05:04:34 DNSServer: Source: ('10.0.1.25', 54193)
05:04:34 DNSServer: Domain: phobos.apple.com
05:04:34 DNSServer: ***forward request
05:04:34 DNSServer: -> DNS response from higher level
05:05:52 DNSServer: DNS request received!
05:05:52 DNSServer: Source: ('10.0.1.25', 62195)
05:05:52 DNSServer: Domain: ax.init.itunes.apple.com
05:05:52 DNSServer: ***forward request
05:05:52 DNSServer: -> DNS response from higher level
Settings
[PlexConnect]
enable_webserver_ssl = True
logpath = .
port_dnsserver = 53
port_pms = 32400
port_webserver = 80
certfile = /Users/Reira/Documents/PlexConnect-master/assets/certificates/trailers.pem
loglevel = Normal
port_ssl = 443
annoyed_lvl = 99
please help..
after trying everything I found online (follow step by step, reboot client & server, delete/restore cert, check path...), I still can't make it work !
here are the logs i get :
16:28:01 WebServer: started: 16:28:01
16:28:01 WebServer: ***
16:28:01 WebServer: WebServer: Serving HTTPS on 192.168.1.60 port 443.
16:28:02 PlexAPI: servers discovered: 1
16:28:02 XMLConverter: PlexGDM - PMS: 192.168.1.60:32400
20:20:16 DNSServer: DNS request received!
20:20:16 DNSServer: Source: ('192.168.1.66', 52473)
20:20:16 DNSServer: Domain: p27-buy.itunes.apple.com.akadns.net
20:20:16 DNSServer: ***forward request
20:20:16 DNSServer: -> DNS response from higher level
20:20:18 DNSServer: DNS request received!
20:20:18 DNSServer: Source: ('192.168.1.66', 58996)
20:20:18 DNSServer: Domain: trailers.apple.com
20:20:18 DNSServer: ***intercept request
20:20:18 DNSServer: -> DNS response: 192.168.1.60
20:20:18 WebServer: serving application.js
20:20:18 DNSServer: Source: ('192.168.1.66', 60285)
20:20:18 DNSServer: Domain: atv.plexconnect
20:20:18 DNSServer: Source: ('192.168.1.66', 57511)
20:20:18 DNSServer: Domain: itunes.apple.com
20:20:18 DNSServer: ***forward request
20:20:18 DNSServer: -> DNS response from higher level
I don't understand the 20:20:18 WebServer: serving application.js line. What does it refer to ?
I'm running both plexconnect and PMS on my synology NAS (DSM 4.3).
It used to work before atv security update. (atv currently on ios 5.3)
Atv always shows the "trailer unavailable, try again later" error...
thanks ;-)
thanks ;-)
Try the Synology thread in this forum for help with your particular setup.
Thanks guys! I set it up from start back home and it worked perfectly!
I have a question regarding streaming through Apple TV 3. Is it always have to be dependable to a Computer running plex media server? What if I just want to stream channels like 1Channel or IceFilms directly to ATV3 let say from an iPad/iPhone?
No strong need for a running PMS. But with the changed DNS setting in aTV (for PlexConnect) you need a local DNS up. This doesn't need to be a computer - a lot of people run it on a NAS or the DNS part on the router...
