PlexConnect.py immediately crashes
Hi guys,
I have PlexConnect working perfectly in my old computer that is using Windows Home Premium 32 bits.
But I have now a new PC with Windows Ultimate 64 bits and cant make the PlexConnect working… when I click, immediately crashes.
What I did?
I have follow all instructions here:
https://github.com/iBaa/PlexConnect/wiki/Install-Guide-Windows
Except:
Installed Python 2.7.6 Windows X86-64 Installer instead of Python 2.7.6 Windows Installer (I tried the other but didn’t worked too)
Installed Win64 OpenSSL v1.0.1f Light instead of Win32 OpenSSL v1.0.1f Light
Installed Visual C++ 2008 Redistributables (x64) instead of Visual C++ 2008 Redistributables
Changed “C:\OpenSSL-Win32” to “C:\OpenSSL-Win64” in the command lines
After all instructions done, when I click in the file PlexConnect.py he immediately crashes.
The don’t see any firewall window open like the tutorial above said.
What I’m doing wrong? How can I fix this?
Waiting for your replies, thank you guys!
Your ATV model (2 or 3) and firmware version (found under the ATV settings > general > about > Apple TV software): ATV 3, 6.0.2 (6646.81.1)
The DNS server set on the ATV (found under the ATV settings > general > network > DNS): 192.168.1.85
The device and operating system (including version number) that PlexConnect is installed on: Windows 7 Ultimate (6.1 build 7601: Service Pack 1)
The local IP address of the device that PlexConnect is installed on: 192.168.1.85
The device and operating system (including version number) that the Plex media server (PMS) is installed on: Windows 7 Ultimate (6.1 build 7601: Service Pack 1)
The Plex media server (PMS) version number you are running (do not put ‘latest’): Version 0.9.8.18.290-11b7fdd
The local IP address of the device that the Plex media server (PMS) is installed on: 192.168.1.85
The PlexConnect version number. If using Github source then a time and date of download (look at the creation date of the folder) and if you are using any testing branch e.g. the Elan/PlexInc one. January 10, 2014 at 04:09 PM
I don’t have any log file or settings.cfg file inside the PlexConnect-master folder.
Try opening a cmd window, changing to the relevant directory and running PlexConnect.py so that you can see any error message.
Hi buddy, thank you for your reply! But I already solved the problem :smiley:
What I did:
- I deleted the PlexConnect-master folder
- I downloaded the file from here: https://github.com/iBaa/PlexConnect/ (Download ZIP link) instead of the link https://github.com/iBaa/PlexConnect/archive/master.zip that is in the tutorial page: https://github.com/iBaa/PlexConnect/wiki/Install-Guide-Windows
After that, is working perfectly! :slight_smile:
Aehm... any chance to figure out the difference of those two packages?
A quick check said "it's the same"...
Baa, you are right, it seems the same, I really dont know what happened but it worked for me :slight_smile:
Ok, just wanted to make sure.
I am glad you got it working - whatever way. :-D
i also had similar case. used the same zip in windows and it crashes. but i used the same on my macbook pro and it worked !
i dont know if it has to do with Python for Windows. I will try once again tonight to get it working with my PC.
*my only problem is with the streaming lag on 720p videos (1Channel, putlocker) on mac. i never have such lag with xbmc. i'll find the related thread. thanks*
Can’t really help you with channel issue but check it is Python 2.7.x you have installed and check my post 2 for troubleshooting steps.
Can't really help you with channel issue but check it is Python 2.7.x you have installed and check my post 2 for troubleshooting steps.
i used 2.7.6. i fixed the problem thanks, it was the Microsoft Visual 2008 C++ which was not compatible. So I installed another version. Open SSL failed to execute properly. so for those who are having issues with PlexConnect, make sure your certificates are correctly acquired
As far as PlexConnect crashing immediately after running plexconnect.py. The guid said to extract the PlexConnect-Master to “C:\Program File”. That didn’t work and crashed immediately. So what I did was, I deleted the extracted file, And I Re-Extracted the file PlexConnect-Master to “C:”. Now it works fine.
As far as PlexConnect crashing immediately after running plexconnect.py. The guid said to extract the PlexConnect-Master to "C:\Program File". That didn't work and crashed immediately. So what I did was, I deleted the extracted file, And I Re-Extracted the file PlexConnect-Master to "C:\". Now it works fine.
Did you correct the permissions if using Windows 7 or later as per the guide?
  1. Extract the PlexConnect archive you downloaded earlier. We recommend extracting it to "C:\Program Files" or "C:\Program Files (x86)" on x64 systems; if you use either of these folders and are running Windows 7 or later ensure that the directory has the correct read/write permissions.
