Hi all, is there a way to change the trailers app icon to the plex icon without using OpenPlex (I'm on windows 7) and without restoring the aTV? I tried it with the iMovieTheater, but this wasn't succesful.
I put a tutorial in the iOS 8 GM topic. Post 165.
https://forums.plex.tv/topic/120584-plexconnect-on-atv-70-gm-ios-80-gm/page-9
If I replace the original files with your files from Post#165, plexconnect won't even start. Did I miss something?
Edit: I had to paste the content of the files manually. Afterwards plexconnect worked normal. Then followed the steps in #165 again and : BAMM! Works like a charm with the trailer icon.
Thanks guys for your great work. Really appreciate it. Greetings from a german plexconnect user ;-)
OK I solved the DNS issue and profile loading issue by restarting my Mac. I don't know why but it's the only way to solve this, just restarting PlexConnect doesn't work. Re-installing PlexConnect or rebooting the aTV doesn't help either and isn't necessary to solve the issue. As I was in the process of testing the Plex icon possibilities, I had to re-do the process more than once and can confirm that in my case, after having the new icon set, it is necessary to reboot my Mac for PlexConnect to work, but it isn't necessary to reinstall PlexConnect.
As for the Plex icon, it does indeed work with both Trailers and WSJ, in addition to iMovie. Screenshots below.
That looks fantastic! Can you do a quick walkthrough for changing the WSJ icon as that's the one I've hjacked?
Thanks in advance...
Post 165:
Does that tutorial work for WSJ too?
Yep
https://www.youtube.com/watch?v=leBK6kgSLkw
Thanks for that! Icon updated and everything almost working perfectly. No problems accessing Plex and home sharing/iCloud working fine too. Struggling with some of the other apps though which just attempt to connect and then fail. Guessing this is plexconnect not passing through the DNS request, but not sure what the problem might be or how to fix. Any ideas?
Cheers
Update - ignore that! Just realised I had switched Little Snitch back on and it was blocking 8.8.8.8
Doh!!!
