PlexConnect without PMS
I would like to share my servers with my in-laws.
Currently my in-laws have a jailbroken ATV2 with the old Plex app on it (ATV and app provided by myself).
Now, my in-laws are not computer literate and they don't have a computer running all the time (and turning on a laptop just to have Plex is a bit too much for them).
As the old ATV app doesn't work with the new PMS releases, I see at the moment two possibilities:
  • Airplay with iPhone or iPad (they have that).
  • Or using PlexConnect.
Would it be possible to install PlexConnect on a VM in the cloud (I can have access to one), for instance on CentOS and by logging into "myplex" have access to my shared servers ?
If yes, what would be the HW requirements for the VM and where would I find the necessary information to install it ?
only if you want a few nasty security holes - why would you not just install it on the ATV2 itself?
Yes, this is possible, as I do the same thing for my parents.  You can probably get away with a VM that has 256-512mb of memory.  Although, if you want to enable fanart, you may want some additional processing power.
Here's the package I use/built to serve remote clients:
https://forums.plex.tv/topic/109406-plexconnect-rpm-for-linux-redhatcentos/
For security purposes, I use dnsmasq and apache instead of the built-in plexconnect services.  I'd also recommend using the provided Settings.cfg, as all the communication/binding happens over the loopback interface.
Best method is to just simply sign into myplex. I personally install plexconnect directly upon my aTV 2’s using baa’s method that I modified into a easy to install .deb (post 231):
https://forums.plex.tv/topic/88905-plexconnect-on-atv2jailbroken-launchctl/page-12
This does a number of things for my aTV 2’s:
  1. Makes them easily portable anywhere I have internet (traveling/vacations)
  2. Installs a dedicated plexconnect app
  3. Installs a dedicated plexconnect host
Thank you very much. I will try this method on my own ATV2 beforehand.
Just a last question: wha'ts the best way to remove the old app on ATV2 (including the icon) and how can I install the Plex Icon with PlexConnect ? As you can see, I am not Linux literate, but I can follow instructions and understand the fundamentals.
And a last question. My ATV2 is still on 5.0.2. Can I still upgrade it to 5.3 (I don't have the latest SHSH blobs) ? is 5.3 for ATV2 still signed ?
Yep. Just restore a fresh new ios.
http://theiphonewiki.com/wiki/SHSH
@wahlman
And a very last question. In the linked thread on your post, you mention to install NitoTV to have SSH on the ATV. If I jailbreak my ATV using Seas0nPass, don't I get SSH as well ?
I believe so if not just install nitoTV. I like nitoTV because it disables aTV updates by installing a few lines in a file to block apple servers upon install. You can install nitoTV (into installer) from any jailbroken device, windows or mac.
