Plexify | OS X Application
tester for 10.8.5, 10.9
Tester for 10.7.5, 10.8.5 and 10.9
@Cyberon how are you handling shutdowns, is is through issuing a command to the daemon/script as your helper app is shutdown or something else?
I can test it on 10.9 if you want to.
Windows Tester here! haha JK!
Can test on 10.9 too :) (and 10.8.5)
can also test on 10.9 and if u want localize for germany if localisation is wanted in further releases
Plexify 1.1βeta
We are excited to announce that we just started the public beta. We worked really hard to bring you the best utility to control PlexConnect. We still have a lot things to do, but Plexify is already powerful and simple! Todays beta contains auto-install support along with several other improvements and bugfixes:
What's New?
  • New User Interface
  • Keyboard shortcuts (quit, preferences)
  • New Preferences Window
  • Welcome guide to help you configure Apple TV certificate
  • New Icon ( Application and Menubar )
  • Certificate generation
  • Download and Install PlexConnect from Github
  • Password will be asked only once!
  • Changed the way to launch and terminate PlexConnect
  • Shows your local IP address
What's next?
Here's what we're planning for the next release of Plexify (Coming Soon)
  • Scheduled startup and shutdown
  • Bring back Restart functionality
  • More global keyboard shortcuts
  • Embed PlexConnect Wiki
  • Auto Update from Github with ability to choose channel
  • Localizations
  • Detection of common errors
  • Notifications for 10.8+
  • Simple way to change settings.cfg from Plexify
  • Better integration with PlexConnect
  • Ability to use your computer as a refrigerator for beer . . .
Known Bugs
"We're working overtime to get it fixed" said Obama
  • PlexConnect auto-start doesn't work
  • Uptime feature is broken
  • Advanced settings are temporarily disabled (there's a reason for that)
System Requirements
10.7+   |  Tested on: 10.9, 10.8.5,  10.8.4, 10.8.3
Contacts
Bug reporting: vahagn.mkrtchyan@mit.edu
Developers: vahagn.mkrtchyan@me.com (iMessage, please use only if you're a developer)
Don't know if it was necessary, but when I installed the public beta, I transferred in my existing certificate files into the Plexify assets folder. Everything worked fine. Have not tried the restart/auto-launch situation.
Please give us your feedback
Your opinion is very important to us. We appreciate your feedback and will use it to evaluate changes and make improvements in Plexify!
It should generate certificate for you. Also, Plexify 1.1 uses PlexConnect from ~/Library/Application Support/Plexify/PlexConnect-master/ directory. You can open it from Preferences too.
Works as advertised on 10.9 enter the password once, nice app :wink:
Guys, if someone tried the app on 10.7 and/or 10.8 please lemme know if it works or not. Also if it doesn't work attach logs from both PlexConnect and Plexify (using Console app). Thanks
Does this use the daemon file? If not, if you did it would solve the Plexconnect restart issue wouldn’t it?
Working great for me on 10.9.
Is there a way to completely reset the app ?
I am on 10.8.5 works like a charm! awesome work guys!  :D
the only thing that dont work is to change the Plex directory for some reason but i can live with that  :lol:
Thanks for the feedback. Regarding your question, there's no way to change the PlexConnect directory. It is designed to work that way.
Not yet, please check Known Bugs section
Everything working smoothly here on 10.9.
I think the tutorial at the beginning can be improved for newcomers. Arrow keys letting them know you can move from left to right would help navigation. Clicking on the dots doesn't seem too obvious. On the otherhand, the auto-install process was perfectly smooth. I had a problem getting the certificate sent to the ATV because at that point of the install Plexconnect hadn't already started. I had to manually click on the icon in the menu bar, press play and then send the certificate to the ATV. Anyway to make this easier for the end user? I knew what was wrong but some might not necessarily know off the bat. Those are the few things I've noticed.
Looking forward to auto-updates being implemented.
Cyberon, this is incredibly good work and will make it easy for many users to get plexconnect running. What a big contribution!
Just a thought... Does it matter what software version the ATV is running?
